Heat shrink solder or crimp butt connectors - Defender Source
Old March 21st, 2016, 09:39 AM
Tesla1Defender
97 D90 NAS SW
Due to corroded/rusted terminals on rear tail lamps 97 D90 going to replace lighting.
Pros/Cons on using butt connectors?
I am either going with the Solder heat shrink butt connectors or the Crimp heat shrink butt connectors.
Preferences?
Old March 21st, 2016, 09:43 AM
I favor heat shrink approach
Old March 21st, 2016, 09:52 AM
BlackField's Avatar
BlackField
Oscar
D110
Both.
I prefer the metal crimps without the plastic sheath and then shrink wrap that.
Solder only on a butt connector will probably be ok but you won't find many technical manuals that support only using solder as a mechanical connection.
Old March 21st, 2016, 09:53 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Just saw your PM.
The solder shrink still requires a crimp, there's just a little lug of solder inside the barrel that melts and ensures a really good connection. They're probably overkill for the application, and you need a really good heat gun to heat the lug to its melting point, but they do work very well.
-Ash
EDIT: He's referring to these.
Geared Restoration Co.
352-572-3236
Old March 21st, 2016, 09:55 AM
BlackField's Avatar
BlackField
Oscar
D110
Crimp it
Old March 21st, 2016, 09:57 AM
Tesla1Defender
97 D90 NAS SW
delcity has combination solder and crimp with heat shrink. Understand about the heat gun but seems the solder connectors are low temp solder at 230 F.
Old March 21st, 2016, 10:03 AM
Crimp.
Old March 21st, 2016, 10:27 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by Ash View Post
Just saw your PM. The solder shrink still requires a crimp, there's just a little lug of solder inside the barrel that melts and ensures a really good connection. They're probably overkill for the application, and you need a really good heat gun to heat the lug to its melting point, but they do work very well. -Ash EDIT: He's referring to these.
^yes*
Look at Ancor first. Genetics are available for cheaper.
Shrink pic cgalpin Misc. Chit-Chat 1 October 27th, 2010 08:28 PM
how to shrink pictures 1000kva Misc. Chit-Chat 1 May 10th, 2008 03:28 PM
Lug wrench - do they really shrink?? paulb Defender Technical Discussions 4 June 26th, 2005 01:42 PM
Fuel skid pain in butt flippedrover Defender Technical Discussions 59 December 15th, 2004 02:44 PM
