Headlight insurance for around $20. (USD) - Defender Source
Old September 4th, 2008, 01:43 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
My truck is 11 years old and I just replaced the stock main head lamp / running lamps switch again, (they appear to last about 5 years). The switch is rather rugged, simple and repairable. But it can (fail) at the most inopportune times. The first time mine failed it was 10 pm - we were out 20 miles from the nearest paved road in the Inyo Mountains boardering death valley - without a functiong switch you have no running lights, instument lights or head lights. Since I wire my aux driving lights on a completely separate circut and switch I was able to safely complete my drive.
The reason they fail is that the plastic base plate that holds the metal contacts within the switch melts and displaces the contacts. The reason the base plate melts is that there is no relay to reduce the load of electrical power passing through the switch.
I consulted the board on how to install a relay -- but got no joy..... so decided to get some external help to make sure I understood how to wire up a relay before I installed my simple and effective relay. Hella make a good relay with a pocket for a standard fuse (clever idea) ($9.) but the headlamp circuts on the rover already have 6 fuses to handle problems. I decided on a bosch 12v 30 amp relay that cost about $12... there are less expensive units ($3 to $4.)
I built a harness and tied it into the segment of the switch that only turns on the head lights - not the running lights and it seems to be working like a champ. I currently have the relay setting outside the dash, just below the instrument cluster so I can monitor any unusual heat that may be generated by the relay. After I am satisfied that it works without issue I will move it inside the dash behind the instrument cluster.
The only modification I made to my factory switch harness was to cut the blue wire (the wire that supplies power to the headlights from the switch) to install 2 bullit connectors. one for going to the relay - the second for comming back from the relay.
Old September 4th, 2008, 03:58 PM
JRW's Avatar
JRW
94 D90 ST #1247
Great idea...
Can you post some photos?
Old September 4th, 2008, 11:21 PM
LenB's Avatar
LenB
Len Bruffett
Sure,
I will take pics either tomorrow or on Saturday. I will have to remove the cowling and facia from the steering column to get the components in plain view. It might be easier for me to draw a picture and label the contacts of the relay and proper config for the harness. The pin out on this type of relay is pretty common. It is the same on an Optronic relay for my day time driving lights, the same pin out on my hella relay for my aux driving lights and the same pin out for the compressor for my hella air horns. Preliminary use tests show that the relay warms up during use - but does not get hot.
Len
Old September 5th, 2008, 02:30 PM
There is a kit sold by ARB to do this for those without DIY harness making skill (not that it is hard to do mind you).
Expedition exchange (among others I am sure) sells it.
ARB Heavy-Duty Wiring Loom (M002) $110
Quantity 1 2 3 4 5 Add to cart
If you want to fit headlights with higher-than-standard-wattage bulbs, you must install the Heavy-Duty Wiring Loom to prevent damage to your factory headlight wiring. The Heavy-Duty Wiring Loom will transfer power directly from your battery to your high-power headlights and will prevent heavy power loads from harming your factory wiring harness. Installation is very simple as the Heavy-Duty Wiring Loom simply plugs into your stock wiring harness' connectors. The ARB Heavy-Duty Wiring Loom is recommended for all Defenders, regardless of headlight wattage used, as the Defenders lack a relay for the headlight wiring harness and frequently burn out factory headlight switches.
Old September 5th, 2008, 10:08 PM
LenB's Avatar
LenB
Len Bruffett
Originally Posted by JRW
Great idea...
I snagged some of my prototype wires and with the some ILM magic I put in some connectors and the schematic for you to follow. The relay trigger spade is usually connected to a power source and a switch. The power spade usually just has power going in. I combined the two power sources with a grafted wire. All of this wiring has crimp fittings and was made up for prototyping harnesses... I have made for multiple harnesses for VDO gages and other lamps in the truck. If you make one of these up I would recommend using soildered connectors. That is what I did for my installed relay and harness. good luck
ID:	15134   Click image for larger version
ID:	15136   Click image for larger version
Old September 15th, 2008, 02:08 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hum.... I am probably looking at this the wrong way. But aren't you supposed to get the 12V to power the lights from the 12V battery feed and not from the switch?
From your picture, it appears the same (actually.... slightly more) power (amps) goes through the switch.
In my mind, the picture would look like this instead (not sure which wire is the 12V input to the switch red or brown, so I played safe).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 6th, 2008, 03:44 PM
MonLand
Loic Fabro
Did you get a chance to try this out?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 9th, 2008, 12:59 AM
LenB's Avatar
LenB
Len Bruffett
I have been super busy this last week...I spent the weekend working on web development projects, But I will do it either tomorrow or the next day and post some picks of the final layout.....
ht, insurance
car insurance roverboy Defender Technical Discussions 3 September 8th, 2005 12:46 PM
headlight bezels aschoent For Sale - Parts 0 August 29th, 2005 02:15 PM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
Military Vehicle Insurance Peter Defender Technical Discussions 2 November 14th, 2003 01:19 PM
