Headlight Guard Design - Page 5 - Defender Source
Old March 15th, 2014, 05:10 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Development Update
Here's the latest.
The attached images shows two new grill designs as well as two addition options for the headlight guards (large and small) using a diamond pattern instead of cross bars. The thought behind the diamond geometry is that it is more stable than cross bars and can therefore be made thinner. I may not produce the diamond guards at all. At this stage I just wanted to see what they look like. Let me know what you all think!
The Small Crossbar Guard is pretty much good to go. I'm very happy with it and i'm definitely going forward with producing it.
The Large Crossbar Guard needed some tweaks. I have beefed up the perimeter of the guard as it warped slightly when cut and I was able to bend it by hand (pushing top-bottom, not front-back). It may be that the span of the bars simply is too long for this particular material & geometry combination to work well, which is why I came up with a diamond pattern that would be more rigid. The next gen prototype should reveal if the changes were sufficient.
The Stock Alloy Grill design Is intended to look as close to stock as possible except it is anodized aluminum not plastic. As Brian mentioned I am also working on a version that has some built in functionality but this will not be revealed until I have a functional prototype.
The Diamond Grill design Uses the an expanded mesh pattern but its is actually water jet cut out of a thick piece of aluminum so it is going to be much more durable and rigid than most grills. Because the material is thicker the ribs can be made pretty thin which increases air flow without comporting strength. The intent is to make the most durable and long lasting grill on the market so unfortunately it may also be the most expensive grill on the market due to extended cutting time and small volume.
Name:	Large Cross Front.jpg
ID:	91254   Click image for larger version
Name:	Large Cross.jpg
Name:	Large Diamond Front.jpg
ID:	91256   Click image for larger version
Name:	Large Diamond.jpg
Name:	Small Cross Front.jpg
ID:	91258   Click image for larger version
Name:	Small Cross.jpg
Name:	Small Daimond front.jpg
ID:	91260   Click image for larger version
Name:	Small Diamond.jpg
Name:	Cross Diamond.jpg
Old March 15th, 2014, 06:18 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I think the diamond grill looks sharp. The all aluminum stock one is a great idea as well.
Any ballpark on price for each?
Old March 15th, 2014, 06:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I like the OEM looking grille. (Small front)
+1 on ballpark cost?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old March 15th, 2014, 10:01 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No price yet. I should know more in the next couple of weeks when I hand over drawings to the fabricator. Prepare for the worst when it comes to cost. They will not be cheaply made. The stock one will be an assembly of many individual bent sheet metal parts, slotted and welded. The diamond one will be water jet cut out of a solid block. The quality should be above and beyond what's currently on the market. That's the goal anyway.
Old April 6th, 2014, 04:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Design update
I made some changes to the small diamond shaped headlight guard today. I moved the mounts so they sit on top/bottom versus left/right. I also made rear light guards in the same diamond pattern that are designed to replace the stock/nas rear light guards. They would fit in the same holes if you already have this style guard.
Name:	Headlight Guard 020714.703.jpg
ID:	92560   Click image for larger version
Name:	Headlight Guard 020714.704.jpg
Name:	Rear Light Guards.705.jpg
ID:	92568   Click image for larger version
Name:	Rear Light Guards.706.jpg
Name:	Rear Light Guards.707.jpg
ID:	92570   Click image for larger version
Name:	Rear Light Guards.708.jpg
Name:	Rear Light Guards.709.jpg
Old April 6th, 2014, 04:50 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I prefer the style of those in your first post.
Old April 29th, 2014, 04:51 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
After 3 weeks of waiting I finally got my anodized samples in today. Looks good and looking forward to wear testing the Type III finish. These designs have already gone through another iteration since then but I will wait to sample those up until after Expo.
Old April 29th, 2014, 04:55 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Very nice!
Old April 29th, 2014, 05:00 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Carl, what vehicle are you taking to the Expo...I need a list of everyone so I can keep an eye open for the D90S guys!!
Old April 29th, 2014, 05:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Oh yeah. I'll be at the Defenders Northwest booth the whole time so come by and see us. We should definitely try to arrange a Defender Source happy hour. I'll be driving my D90.
Old April 29th, 2014, 05:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks! They should be great once finalized.
Originally Posted by Wilboro View Post
Very nice!
Old April 29th, 2014, 05:12 PM
VictorA's Avatar
VictorA
Victor Atkins
'94 D90 SOLD
All your designs look great!
Carl - two somewhat off topic questions:
What CAD program are you using? All the renderings look fantastic, nice work!
Also what headlights are you running on your 90? They look pretty awesome. Aftermarket LED?
Old April 29th, 2014, 05:14 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Solidworks for modeling and Keyshot for rendering. I have JW Speaker 8700 Evolution Headlights installed (LED).
Old May 11th, 2014, 07:51 PM
ymc226
Lawrence
1995 D90 SW NAS
Great products Carl,
I'm in for everything . . . . once I get a Defender. Will you be posting on the forums once they become available?
Old May 11th, 2014, 09:03 PM
How are the production plans coming along?
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Lawrence! I'll definitely post details as they become closer to being ready. I'll also be at the Defenders Northwest booth at Overland Expo anyone planning on attending, swing by!
Old May 11th, 2014, 09:09 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Slowl but making progress. First round of prototypes will be at Overland Expo and I'll start second round which are already designed once I get back. I'm also broadening my scope of fabricators and getting more quotes. I hope to shoot for July or August and I will post date and pricing here once they have been determined. Photos of the 1st round will be on my website (www.tiktaalik.com) which should be up and running on Thursday next week.
Old May 16th, 2014, 01:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Release date, Pricing and Pre-order list
The website is now live. The small and the large headlight guards will be available on October 1st. The small headlight guard will be $249 and the large headlight guard will be $299. They will be fabricated in small batches in Portland, OR and they will come with hardware and mounting nuts. If you're interested in either item PM me and I will put you on the pre-order list. Shipping will be free for D-90 members on the pre-order list. The guards are on display at Overland Expo this weekend. Come by the Defenders Northwest booth and take a look at the 1st gen prototypes. 2nd generation with improvements will be finished in a couple of weeks.
ID:	95088   Click image for larger version
ID:	95090   Click image for larger version
ID:	95092   Click image for larger version
Old May 18th, 2014, 09:34 PM
ymc226
Lawrence
1995 D90 SW NAS
Any news on the grills?
Old May 19th, 2014, 07:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Still traveling back from Overland Expo. The plan is to prototype both the aluminum OEM version and the Diamond version grill. Will be a couple more weeks before I have photos of those.
aluminum grill, custom, design, fabrication, headlight guard, military grill, nas, nas lamp guards, rear lamp guards, rear light guards, stage 1, wolf
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Steering guard bracket design maleger Defender Technical Discussions 4 December 5th, 2010 06:38 AM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
NAS Wrap-around Grill Guard for sale SFD90 For Sale - Parts 11 October 28th, 2004 01:17 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
