Headlight Guard Design - Page 3 - Defender Source
Old December 18th, 2013, 10:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
This is the direction I was going with it personally for my own rig (left image). I was going to replace the plastic surround with a stamped aluminum one then paint both body color. Right image shows black guard on body color. My model is not accurate underneath the surround so thats why I showed you these instead.
How about a pic without the plastic surround behind the guard?
-Jeff
Name:	Headlight Guard 102413.476.jpg
ID:	86389   Click image for larger version
Name:	Headlight Guard 102413.485.jpg
Old December 19th, 2013, 03:04 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It is illegal in Virginia to have anything (guard) in front of the headlamps. Check your local regulations.
Edit
Semper Fi!
Old December 22nd, 2013, 04:45 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Here's some additional options.
Pic 1: Current design, headlight guard.
Pic 2: Alternative to current design (less material, simplifying fabrication).
Pic 3: Full Cover headlight guard. The full cover guard mounts to the same 4 existing holes. No drilling required.
Comments welcome.
Name:	Headlight Guards 122113.499.jpg
ID:	86543   Click image for larger version
Name:	Headlight Guards 122113.497.jpg
Name:	Headlight Guards 122113.498.jpg
ID:	86545   Click image for larger version
Name:	Headlight Guards 122113.500.jpg
Old December 22nd, 2013, 04:50 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Man what happens if you like all three!! Nice work...gotta start a poll soon.
Old December 22nd, 2013, 04:56 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Threeeee! looks like a part of the surround instead of an add on, looks good!
Old December 22nd, 2013, 04:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The alternative version is a little bit more of a departure from the Rover "language". The first one was intended to resemble the series headlight finishers as in this rendering. Something that looks more familiar and that would look good on series too. The full version should be pretty sturdy. I am considering removing a bar from the bottom and making it shorter in height because its a waste of material since its not protecting anything at the bottom. I'll probably end up making 1 & 2. Unless a majority favors #2 over #1.
Name:	Headlight Guards 122113.501.jpg
Old December 22nd, 2013, 04:59 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks!
Since it bumps out further due to the marker lights it should match up nicely with the bumped out grille for those who have that.
Old December 22nd, 2013, 05:09 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Aluminum Surround
One more thing to get your input on. I am also in the process of making a set of aluminum headlight surrounds. I plan just to make a set for myself or if there is interest, for others. The challenge I am trying to overcome here is the trim ring around the headlight. The surround would be stamped and I'm trying to come up with a more cost effective way than machining the trim ring. Personally I love the clean appearance of the body painted aluminum surround (pic 2).
Name:	Headlight Guards 122113.502.jpg
ID:	86549   Click image for larger version
Name:	Headlight Guards 122113.503.jpg
Old December 27th, 2013, 12:39 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have made some design refinements. Here are the two design that I will go forward with. I plan to send out a quote packet for these today. 1. Headlight Only Guard. 2. Full Coverage Guard. Both will come with flush mounted security screws. I made the full coverage guard shorter in height so that it is symmetrical in relation to the mounting holes so that it doesn't matter which side you mount it on.
Name:	Headlight Guard 122613.504.jpg
ID:	86721   Click image for larger version
Name:	Headlight Guard 122613.505.jpg
Name:	Headlight Guard 122613.506.jpg
ID:	86723   Click image for larger version
Name:	Full Coverage Guard 122613.508.jpg
Name:	Full Coverage Guard 122613.509.jpg
ID:	86725   Click image for larger version
Name:	Headlight Guards 122113.511.jpg
Name:	Headlight Guards 122113.510.jpg
ID:	86727   Click image for larger version
Name:	Headlight Guards 122113.513.jpg
Name:	Headlight Guards 122113.515.jpg
Old December 27th, 2013, 01:10 PM
Think you are on to something!
Old December 27th, 2013, 03:37 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I think so!
Old December 27th, 2013, 05:56 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I like the alu surround idea. Even better if NAS design was available as well. To complete the front end package how about an aluminum version of the traditional front grille!
Old December 27th, 2013, 07:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What's specific about the NAS surround other than it accommodates the comically large turn signal lamp? Aluminum grille is already in the sketch book.
Old December 28th, 2013, 09:08 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Here is a pic Carl, looks like the large turn signal is positioned lower. Pic shows early NAS vs Late. I think Rows are same as early NAS?.
Old December 30th, 2013, 12:45 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yes. I will make the surround for ROW first. Both light guards should fit the NAS style arrangement but I have yet to verify.
Old February 17th, 2014, 12:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Bump to let everyone know that this is still in progress. Currently waiting for next set of prototypes.
Old February 17th, 2014, 01:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
They are…
And from what I have seen on the initial prototypes, these are going to be very nice indeed!
Old March 6th, 2014, 05:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got first round samples in today. Some small adjustments need to be made but overall they're looking pretty good. They're bare aluminum right now.
ID:	90845   Click image for larger version
ID:	90847   Click image for larger version
Old March 6th, 2014, 05:22 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
WOW, just wow! Nicely done. If the previous owner hadn't already screwed in to the metal light guards, I'd be all over these!
Old March 6th, 2014, 05:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks! The nice thing about these is that they use existing surround mounting holes. I plan on shipping them with new nylon nuts as well as flat torx hardware. They're also symmetrical so either one can fit either side. The large one lines up nicely with the surround behind it.
aluminum grill, custom, design, fabrication, headlight guard, military grill, nas, nas lamp guards, rear lamp guards, rear light guards, stage 1, wolf
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Steering guard bracket design maleger Defender Technical Discussions 4 December 5th, 2010 06:38 AM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
NAS Wrap-around Grill Guard for sale SFD90 For Sale - Parts 11 October 28th, 2004 01:17 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
