Headlight Guard Design - Page 2 - Defender Source
Old December 18th, 2013, 12:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Isn't what the old series grills were also used for?
Originally Posted by Bill Larson View Post
would need quick disconnects! but really there might be something there! Kinda like tin foil on a manifold (lamb shank, butter and green onion).
Old December 18th, 2013, 01:14 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
It is called the breakfast afterall
Old December 18th, 2013, 06:25 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
First Aluminum Prototypes
I picked up the first aluminum prototypes today and they look good. I was pleasantly surprised about the rigidity as well as the low weight. Unlike the prototype in the photos, the final version will also be welded, ground and polished on the sides so there will be a smooth seamless finish all around leaving no marks or blemishes. They will be made from 3/16" thick 5052 Aluminum that is laser cut, welded, ground, polished and sand blasted then finally anodized black using Type III Anodization. I will be receiving a quote next week and there will likely be a minimum of 20 pairs for it to happen.
ID:	86356   Click image for larger version
ID:	86358   Click image for larger version
ID:	86360   Click image for larger version
ID:	86362   Click image for larger version
Old December 18th, 2013, 06:35 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Do you know if they'll fit NAS?
Old December 18th, 2013, 06:36 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Not yet. Perhaps someone can tell me the diameter is on the NAS turn signal?
Old December 18th, 2013, 06:38 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Next you need to make covers for the parking and turn lamps similar to the Equip/COR4 ones. Same process as yours, laser cut, interlocking, anodized, except you only do horizontal bars vice both.
Semper Fi!
Old December 18th, 2013, 06:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I am working on a design with complete coverage exactly how you describe.
Old December 18th, 2013, 06:47 PM
Bill Larson
Bill Larson
Yeah trucks in the shop for CV's. Sorry.
Old December 18th, 2013, 06:56 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Interested...
Defender 110
Old December 18th, 2013, 07:03 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
complete coverage of all lamps design would be a plus, even more so if someone could figure out a design that does not need to be drilled into the wings.
(like a lamp surround that has integrated grille)
Old December 18th, 2013, 07:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you think there would be enough interest for a surround with integrated grille? I'm working on an aluminum replacement for the headlight surround and I was considering adding bars to it. Whatever the solution is I'm going to do my best to try and avoid drilling.
Originally Posted by thewap View Post
complete coverage of all lamps design would be a plus, even more so if someone could figure out a design that does not need to be drilled into the wings. (like a lamp surround that has integrated grille)
Old December 18th, 2013, 07:44 PM
C391HAT's Avatar
C391HAT
Zach
86 110
I like the surround with bars idea but I see a potential problem. How will the design allow for changing bulbs? The way I'm imagining it you'd have to remove the entire surround to change a bulb. And to remove a surround you have to remove both lenses and bulb holders, which seems difficult with the bars in the way. On the lamp guards I have the top screws come out while the bottom stay in so it flips down to access bulbs
Old December 18th, 2013, 07:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Agreed. A full coverage design should probably have a hinge.
Old December 18th, 2013, 07:55 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I think its perfect the way it looks now. Simple.
Although the marker lenses are what are prone to breaking, so maybe you could design some tiny ones for the marker lenses?, or enlarge to cover the lenses?
I don't see a problem with it not having hinges. I mean how difficult is it to remove four screws? Are we really changing bulbs that often?
I'd run these as-is and maybe get some of those small cages that RN sells for the turn signals.
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
It is illegal in Virginia to have anything (guard) in front of the headlamps.
Check your local regulations.
Rent my
Old December 18th, 2013, 08:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I agree. That's why I started with the headlight-only design. Headlights range in price all the way up to $1500 while turn signal lamps are... cheap.
Originally Posted by Jackie Treehorn View Post
I think its perfect the way it looks now. Simple. Although the marker lenses are what are prone to breaking, so maybe you could design some tiny ones for the marker lenses?, or enlarge to cover the lenses? I don't see a problem with it not having hinges. I mean how difficult is it to remove four screws? Are we really changing bulbs that often? I'd run these as-is and maybe get some of those small cages that RN sells for the turn signals.
Old December 18th, 2013, 09:07 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Agree.
Old December 18th, 2013, 09:35 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
For now I'll proceed with the headlight-only version and I will model up some options to look at in SolidWorks of the full coverage version but I won't proceed to make anything of the latter unless its a simple and appropriate solution. I have more ideas than I can possibly make and there are other product ideas that I'd like to get to before this one.
Old December 18th, 2013, 09:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's what I did when I bought my truck. You just need a new set of surrounds and turn signal lights. Both are cheap. I considered counter sinking the mounting holes but hesitated to make it too thin in that area. It's probably fine though. The plan was to source fasteners to go with the kit. If I find a low profile screw so that it is flush mounted it could be worhtwhile. "Security" screws would be nice. Also it adds another step in the process since the laser won't do it which might affect quote a little.
You could always swap the goofy sized lights for some normal looking ones. Carl, will the mounting holes be counter sunk? -Jeff
Old December 18th, 2013, 10:14 PM
Bill Larson
Bill Larson
-Jeff
Next you'll be offering the idea that Brits and dental braces make good common sense!...think I'll keep them as intended...(for now).
aluminum grill, custom, design, fabrication, headlight guard, military grill, nas, nas lamp guards, rear lamp guards, rear light guards, stage 1, wolf
Rovers North Front Headlight Guards $180 Wolf Fabrication For Sale - Parts 2 November 2nd, 2011 08:41 PM
Steering guard bracket design maleger Defender Technical Discussions 4 December 5th, 2010 06:38 AM
Mesh Headlight Guard NashvilleRedD90 Defender Technical Discussions 5 April 18th, 2005 03:20 PM
NAS Wrap-around Grill Guard for sale SFD90 For Sale - Parts 11 October 28th, 2004 01:17 PM
headlight switch sub jorge Defender Technical Discussions 1 January 24th, 2004 09:10 PM
