Glass Fuses - Defender Source
Old January 1st, 2016, 12:46 PM
MisterSHO
David K
87 110, 95 RRC
Glass Fuses
So I traced a few problems back to the glass fuse panel (obv), cleaned the connections, and set new fuses. Nothing. Went to try and roll the fuse around a bit and found that when I apply pressure and push it inwards a bid, the fan started working! Obviously, switching to blades is the right move; however, does anyone have a temporary fix for maintaining that connection? Is there any way to manipulate the clips to set the fuse in where it needs to be? Thanks so much. Dave
Old January 1st, 2016, 01:07 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Get a fibreglass contact cleaner pen from Tandy or any electrics shop or rap some very fine emery cloth around the fuse and give a couple of turns. More likely the holder is green dirty.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
glass
Glass to Blade fuses BostonAndy Smaller Projects 14 April 23rd, 2015 01:47 PM
Replacing glass fuses with blade fuses ? Chris Velardi Defender Technical Discussions 10 December 21st, 2011 08:13 PM
97 D-90 SW blowing fuel pump fuses intermittantly BarryO Defender Technical Discussions 9 July 20th, 2004 03:07 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
