Gas tank guard replacement - Defender Source
Old May 12th, 2016, 10:49 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
So, working on replacing my gas tank guard. I have a 95 NAS ST with a sway bar.
Looks like the gas tank is held up by the tank guard? It is dropping while I'm trying to remove the old guard.
Any suggestions on how to replace without messing the tank up? Not sure how I'm gonna hold the tank up while replacing the guard.
Old May 12th, 2016, 10:27 PM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Called Lucky8 - helped me out. Used ratchet straps to hold tank up. Went very smoothly after that.
Never thought I would stare at a skid plate for so long.
Old May 13th, 2016, 03:10 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I did that same job. Use a lot of anti seize on the hardware so you can drop the tank with more ease to get at the fuel pump in the future. Also a good time to hit the exposed bolts and the fuel tank mounts inside and out with waxoyl
And nice Arles BTW
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old May 13th, 2016, 05:34 AM
This type of surgery best performed on an empty tank!
Gas tank evapoation tank- 1997 D-90 Tyler Wirken Wanted 2 January 29th, 2010 11:22 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
QT rear diff guard rubs gas tank cgalpin Defender Technical Discussions 27 March 23rd, 2009 08:53 AM
Gas tank guard cover problem... FlaD90 Smaller Projects 9 April 28th, 2008 09:28 PM
Gas Storage--Gone Bad? When will gas go bad in a Jerry Can? pcscharfe Misc. Chit-Chat 7 August 29th, 2007 05:42 PM
