Fuse Box - Defender Source
Old February 12th, 2013, 01:43 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Fuse Box
So I wanted to have power in the back of the CT but also didn't want a bunch of sloppy wires zip tied to the roll cage so I started a project to clean up the wiring and provide for a fused system that was expandable in the future. Here is what I came up with.
Ran welding cable from a circuit breaker in the battery box. Power all from secondary battery. Entered the rear cargo area and hooked into power distribution blocks. This way the compressor has a nice clean feed of 2/0 gauge wire and then off to the "fuse box"
ID:	66109Click image for larger version
I then used bulkhead glans to create a waterproof in/out to a pelican box
ID:	66111Click image for larger version
ID:	66112Click image for larger version
These connect to a blue sea 12 station fuse box. Click image for larger version
Then out to the devices that need power. This will allow for fused power with each device on its own circuit. Also allows to easily add a circuit.
Since the box is tucked away I wanted to be able to access it easily so waterproof quick disconnects were put in place out side of the box, all hidden behind the box when installed.
ID:	66115Click image for larger version
ID:	66116Click image for larger version
ID:	66117Click image for larger version
ID:	66118Click image for larger version
Con't
Old February 12th, 2013, 01:47 AM
El Solis's Avatar
El Solis
Chris Solis
Con't
I do recommend the $2 removal tool Click image for larger version
I also am using the kicker pxi50.2 iPod controller which has a faceplate to allow for remote control of the iPod/iPhone which is weather resistant and has big buttons easy to see when bouncing alongClick image for larger version
Allows me to keep my iPod in the pelican safe and sound with the amp (and the relays for the rear work lights)Click image for larger version
Once I'm done I'll post the rest, have to make the connectors in the car Click image for larger version
Old February 12th, 2013, 07:49 AM
Great work so far! I implemented similar strategy for powering my rear cargo area. What's your source for the weathpak connectors and which crimper did you get?
Mark Kellgren
KM4BOR
Old February 13th, 2013, 12:02 AM
El Solis's Avatar
El Solis
Chris Solis
I found them on amazon but I think it is just weatherpack.com. as for a crimper I just hand folded the tail part and then used a needle nose to crimp it down. Guess we will see how it works
new fuse box cover mattdh For Sale - Parts 10 March 29th, 2006 01:24 AM
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
Need fuse box thumb screw evilfij Wanted 1 June 20th, 2005 10:24 AM
Engine Fuse Box Cover thug1313 Wanted 3 April 20th, 2005 07:26 PM
