Front door stays - Defender Source
Old October 7th, 2016, 01:34 AM
kurtisblo's Avatar
kurtisblo
Kurt
1991 Defender 110, LHD 200TDI
Front door stays
Anyone have the part number for the front door stays for a ROW 1991 110? The part that is attached to bulkhead that helps the door stay open. Couldn't find on Roversnorth or in a parts catalogue.
Old October 7th, 2016, 01:47 AM
Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Old October 7th, 2016, 01:53 AM
SARTech
P. Barber
1989/Defender 90
If you talking about the Torsion Bar, the 'S' shaped level that presses on the roller end of door check strap. rovahfarm.com has them # ALR2318 of RH doors and ALR2319 for LH door.
Hope this helps.
PB
Old October 7th, 2016, 02:05 AM
kurtisblo's Avatar
kurtisblo
Kurt
Originally Posted by SARTech View Post
If you talking about the Torsion Bar, the 'S' shaped level that presses on the roller end of door check strap. rovahfarm.com has them # ALR2318 of RH doors and ALR2319 for LH door. Hope this helps. PB
thanks. Yes that is part of it. But I need most of the parts shown in the below photo for right side door
Old October 7th, 2016, 11:15 AM
SARTech
P. Barber
1989/Defender 90
RovahFarm.com has all those parts listed.
Land Rover Parts and Accessories from RovahFarm
RovahFarm for all your new Land Rover Parts and Accessories
Old October 8th, 2016, 12:26 AM
kurtisblo's Avatar
kurtisblo
Kurt
Thanks. I took off the trim piece and realize that the Torsion S bar is pulling away from the bulkhead when the door opens. One of the bolts appears to be stripped and is not tightening into the bulkhead to keep the torsion bar in place. Any ideas on how to fix the stripped bolt?
Old October 9th, 2016, 10:57 AM
kurtisblo's Avatar
kurtisblo
Kurt
Any ideas appreciated on fixing the bolt that won't tighten into the bulkhead
Old October 9th, 2016, 11:37 AM
SARTech
P. Barber
1989/Defender 90
I have the same issue, one bolt was stripped. I replaced the bolt and so far its working ok. I know that at some time I will have to replace the nut plate.
Old October 10th, 2016, 01:39 AM
kurtisblo's Avatar
kurtisblo
Kurt
Thanks. I am having a hard time even getting the stripped/loose bolt out. I feel like there is probably a nut on the backside that I cannot access that is just spinning as I try to unscrew the bolt
Old October 10th, 2016, 01:48 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Right hand door:
MWC5018– check strap slider x 1
ALR2318 – check strap torsion bar x 1
MUC6157 – bracket-pivot check arm x 1
SH106301L – bolt M6 (30 mm) x 2
WA106042 – washer M6 x 2
MWC5759 – check strap buffer x 1
On your own for left.
KGH - “Stinky LR diesel” Defender Snob
Old October 16th, 2016, 11:48 AM
kurtisblo's Avatar
kurtisblo
Kurt
Is there a nut on the backside of the plate that tightens the bolt? In other words, when you unscrew the bolt, is it coming out of a nut that keeps it tight? Otherwise, what does the bolt tighten into?
Old October 16th, 2016, 02:53 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
the nut is welded to the plate, so called a nut plate
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 16th, 2016, 03:26 PM
On my bulkhead, the two screws holding in the torsion bar are threaded into the bulkhead (there is no nut plate.)
There is also a three-screw version (updated) of the door stay bracket, which has a third screw that mounts to the bulkhead. Older bulkheads don't have a hole for this third bracket hole.
Series IIa Door Stays roverguy Series Technical Discussions 3 March 8th, 2016 11:03 AM
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
SW Door Catch (strikers) / Stays / Catch Rods / Trim FS SafariHP The Vendors Loft 5 February 8th, 2009 11:04 PM
Softtop stays D90user For Sale - Parts 3 January 30th, 2007 04:20 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
