Finished adapter GM 4L60E to LT230 - Defender Source
Old June 5th, 2016, 07:37 PM
ezzzzzzz
Mark Garrenton
First and foremost, a great big thanks to Charles Galpin for sending me the spare mainshaft!
The shaft was cut and machined (muthalickin hard metal in some places) then pressed into a GM yoke I machined down and bored for a friction fit. The shaft was then tig welded (two passes) at a local shop as my Syncrowave 250 hasn't been set up yet. Here is the finished product that I built using the original Novak-Adapt 4L60E to Dana 300 adapter I designed years ago. The front spacer came out of the 6061 8"x5" chunk in the lathe. The rear plate was fabbed from 6061 12"x12"x1" flat stock. Everyone is jumping on the LSx wagon (with good reason) but I have a spare LT1 and 4L60E waiting for a project (I'm probably fitting it into my '84 110). I also included a couple of photos of my hybrid '88 LS1 project started several years ago but still waiting completion.
Name:	P5171404 (Small).JPG
ID:	150987   Click image for larger version
Name:	P5171405 (Small).JPG
Name:	P6051409 (Small).JPG
ID:	150989   Click image for larger version
Name:	P6051411 (Small).JPG
Name:	P6051412 (Small).JPG
ID:	150991   Click image for larger version
Name:	P5171402 (Small).JPG
Name:	P5171403 (Small).JPG
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old June 5th, 2016, 08:27 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Simply awesome
Old June 5th, 2016, 08:38 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Cool. What do you plan to do to the brakes?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old June 5th, 2016, 08:50 PM
ezzzzzzz
Mark Garrenton
The LS1 88" coiler uses Currie 9" hi-pinion axles with Dana 44 front knuckles and brakes and Ford Explorer disc in the rear. The 110 will get vented 110 rotors/calipers and better pads all around. Stopping power isn't any more an issue with a bigger engine than a stock unit. Larger tires and heavier loads have the impact.
'90 RRC
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old June 5th, 2016, 08:57 PM
hydroboost ?
Old June 5th, 2016, 09:14 PM
ezzzzzzz
Mark Garrenton
hydroboost ?
That's an option. I've considered it on the 88" even playing with a unit and bracket but it is on hold like so many projects. With retirement, I'm going get some stuff completed over the next year or so.
'90 RRC
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old June 5th, 2016, 09:41 PM
Be cool to see the Nigerian Princess/ 110 up and running
Old June 6th, 2016, 03:40 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Will the LT230 relocated?
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
Old June 6th, 2016, 08:29 AM
ezzzzzzz
Mark Garrenton
No. Like Nick's gen III setup, the engine is pushed forward 4". There's enough room in a 90/110 for that move.
'90 RRC
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old June 6th, 2016, 09:15 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Lookin good Mark
lt230
Mark's 4WD LT230-Th400 T-Case adapter W/GM V8 motor mounts .alan. For Sale - Parts 1 October 15th, 2015 08:18 PM
1982 Jeep Scrambler 5.3 Vortec & 4L60E conversion, CLEAN Lots of Mods. WTB 109/110 speedpin For Sale - Vehicles 5 November 2nd, 2014 02:09 PM
LT230 to NV4500 adapter andy110 For Sale - Parts 18 April 2nd, 2014 08:17 PM
LT230 adapter Vader For Sale - Parts 6 September 7th, 2013 01:16 AM
NV500/LT230 Adapter rondo Wanted 2 January 14th, 2011 06:20 PM
