Fabricating a Chuck Box / Mobile Kitchen - Defender Source
Old January 18th, 2012, 06:59 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Right now all my kitchen stuff is haphazardly tossed in a plastic trunk. It's not organized and it drives me crazy. After searching around, I really wanted a Kanz box, but the $700 price tag was a bit much. I finally settled on an all-aluminum Zarges case weighing in at 17lbs empty. It was $380 delivered.
My goal is a free standing unit with collapsable legs where the lid opens to serve as a cooking surface. There will be various shelves for cooking items, and places for containers holding utensils, spices, small items, etc.
I started by bending up some shelves. I went overkill by rolling a bead into the first shelf and quickly realized it was a waste of time.
More to follow....
ID:	46300   Click image for larger version
ID:	46302   Click image for larger version
ID:	46304   Click image for larger version
Semper Fi!
Old January 19th, 2012, 04:17 PM
Wolf Fabrication
Sterling Archer
'08 D3
Starting to come together....
Semper Fi!
Old January 22nd, 2012, 12:56 PM
Wolf Fabrication
Sterling Archer
'08 D3
Got all the compartments built. Working left to right: Stove, red bag is pots and pans, below that is the plates, bowls and cups. The large black bin holds all the utensils, the two little ones hold spices, dry food, and other tiny items. Above those is the first aid kit and lantern. The large area is for food (junk right now), and the two small compartments hold propane.
It looks full right now, but I still have tons of space to spare. Zarges makes a multiple-pouch attachment that mounts inside the lid that I may still install.
Still working on legs of some sort...
Semper Fi!
Old January 22nd, 2012, 02:54 PM
Wolf Fabrication
Sterling Archer
'08 D3
Testing out leg options. I thought this folding camp table would work, but it's too side heavy with a stove on the work surface. I'd also like it to be higher up.
Semper Fi!
Old January 22nd, 2012, 02:57 PM
aka rover's Avatar
aka rover
ed angel
95 D90
That is sweet!
I have been pondering a custom case out of wood or ? but I really like what you have done here. I think ill look into doing the same thing. Thanks for the pics and the thread, you did a great job.
85 D110 3.5 3 DR
Old January 22nd, 2012, 03:09 PM
Wolf Fabrication
Sterling Archer
'08 D3
Actually, I found if you slide the box back on the table it's more stable (obviously), tilts the box back a tad (which helps keep things inside), and the table supports the lid.
Voila!
Semper Fi!
Old January 23rd, 2012, 09:39 AM
I like the compartmenting.
It's rare you find perfectly level ground, so something with adjustable/telescoping legs would be ideal.
Originally Posted by pendy
I'm here for the D's
Old January 23rd, 2012, 09:48 AM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah. I am looking at telescoping leg options and how to attach them to the box. The key is that they need to go out at an angle to stabilize the box. With the lid open and a stove on it, it becomes top heavy. I'm thinking of making little "pockets" on the sides of the box for the legs to slide in to.
It actually works fine sitting on a flat table too. My little folding camp table fits nicely inside the box.
Semper Fi!
Old January 23rd, 2012, 11:02 PM
discotdi
Todd Miller
Land Rover
Where did you buy the box?
Old January 24th, 2012, 07:39 AM
Wolf Fabrication
Sterling Archer
'08 D3
Overland Gourment. They had the best price with shipping, although a limited selection. Kanz looks to have the most selection if you don't find the size you need. I hindsight I think I should have gone a tad smaller, but I was set on have my stove fit along the side.
Semper Fi!
Old April 4th, 2012, 10:56 AM
Wolf Fabrication
Sterling Archer
'08 D3
As an update to this thread, I finally found a solution for legs. I used 5/8" threaded couplings welded to steel plates at offset angles and riveted those to the box (I replaced the small rivets in the pics with larger 3/16" rivets). The legs are 3/4 steel tube with a threaded end and a length of 5/8" threaded rod so you can adjust the box for level and height.
ID:	49922   Click image for larger version
Semper Fi!
Old August 9th, 2017, 01:48 AM
swb88in
Hans
Defender 130
nice
Old August 9th, 2017, 02:00 AM
swb88in
Hans
Defender 130
I also used a Zarges case to make a chuck box.
I hope to post images soon.
Old August 9th, 2017, 02:06 AM
swb88in
Hans
Defender 130
My chuck box
Name:	DOCK closed.jpg
ID:	279370   Click image for larger version
Old August 9th, 2017, 08:15 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Looks good, Johnathan.
RDavisinVA
Old September 10th, 2017, 08:18 AM
swb88in
Hans
Defender 130
some movies;
https://youtu.be/ObsBCcZz5Do
https://youtu.be/phtic7xzHzM
Regards,
DOCK
Old September 10th, 2017, 08:50 AM
swb88in
Hans
Defender 130
and a link to my website;
www.dockoutdoors.com
Old September 10th, 2017, 09:39 AM
vtlandrover
Frank
1991 200Tdi 110 Hicap
Hans -
I couldn't possibly be more impressed.
Have you set a price inclusive of shipping to the States?
- Frank
Old September 10th, 2017, 09:48 AM
swb88in
Hans
Defender 130
Hi Frank,
Thank you very much for the compliment!
Price is 795.- euro
Shipping will be around 100.- to the US.
But please be patience, we made some improvements and want to sell the ”left overs” in Europe first.
Then we will manufacture a new batch ready for shipping.
More info on; www.dockoutdoors.com.
we will keep you posted.
Best regards,
DOCK, Hans
kit
Passenger Seat Box gtg067i Defender Technical Discussions 13 August 4th, 2009 09:26 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Tailgate Subwoofer Box and Speaker boshea For Sale - Parts 9 December 21st, 2005 11:47 AM
Waterproofing speaker box? Helihntr Defender Technical Discussions 9 May 26th, 2005 12:31 PM
