Exmoor Trim Install - Defender Source
Old November 20th, 2012, 11:52 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Exmoor Trim Install
So following up on the other trim post(s) these are the photos from the completed project. The Exmoor product is pretty good. I would say it’s worth the cost. You just have to take you time and get the notching right. I had to modify where the bonnet release handle is and where the AC drain tube exits. I used a Dremel for some of the notching, what I found with that is it makes too many particulates…if you use a higher speed it melts the mat and provides a smoother finish for the notch.
It took me longer than I anticipated because I wanted to do some touch up pant on the boxes and I cleaned and used Dynamat and or cool it from Summit (no reason for the mix I had both so…). The main problem was/is the center console now sits ¼” higher not allowing the shifter trim piece to fit. I’m going to raise the shifter platform to compensate. In the end the difference is noticeable right now, but we will have to wait for the summer highs of 110 and a road trip.
Total time for cleaning, paint, trim and sound deadening- 8 hours give or take over a 14 hour day.
Name:	New Braunfels-20121105-00573.jpg
ID:	61241   Click image for larger version
ID:	61243   Click image for larger version
ID:	61245   Click image for larger version
Name:	New Braunfels-20121105-00571.jpg
ID:	61247   Click image for larger version
Old November 27th, 2012, 09:00 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
very nice!
Old November 27th, 2012, 10:09 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
Very nice job. I have the same matting system in my 110, just a shame the Army didnt do as nice a job when they fitted it to the 110 as part of the Tithonus project.
Old November 28th, 2012, 12:46 AM
Bill Larson
Bill Larson
Thanks, it was worth it!
Old November 28th, 2012, 01:40 AM
Skeena river rover
jeroen
1997 300 TDI 110
ps do you have a noticeable sound reduction?
Old November 28th, 2012, 07:47 AM
Bill Larson
Bill Larson
The noise is reduced by about 1/3 and the heat exchange by 1/2.
Old November 28th, 2012, 08:20 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Bill, I see you have an auto, without the NAS console? Do you think this trim would fit under a NAS auto console?
14 hours total 8 hours install six hours for drinking. Impressed!
Old November 28th, 2012, 08:23 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Edit: Fit without modifying the console if it took the place of the original carpeting, i should say.
Old November 28th, 2012, 09:38 AM
Bill Larson
Bill Larson
Yeah there is a 1/4 inch elevation problem. I'm resolving that by raising the shift platform 1/4" to allow the trim piece to go back in place. The console was super easy to remove, you just have to be careful and think it through. There is a post on it and ECR has a post also on their site.
Name:	New Braunfels-20121128-00633.jpg
ID:	61721   Click image for larger version
Name:	New Braunfels-20121128-00634.jpg
Old November 28th, 2012, 09:39 AM
Bill Larson
Bill Larson
I already operate impaired...that said no drinking on this job!
Old December 16th, 2012, 05:14 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Bill, did you get the shifter trim installed? Im about to do this myself if you got that elevation issue resolved. Which Exmoor Kit did you get, the R380? Did it come with those 3ish pieces as shown in your first pic or did you purchase separate pieces? Im tired of smelling wet dog from the PO. Thanks!
Old December 16th, 2012, 07:16 PM
Bill Larson
Bill Larson
Yes I installed the three piece. Didnt fix the shifter issue yet, but my confidence is high that it wont be a big deal at all. Just make sure your plan of attack is well organized. Even though I thought the notching was right I made three mistakes. Youll have the AC drain to contend with and the bonnet release. This is a helpful link for removing the center console, if you dont already have it. http://www.eastcoastrover.com/LEDflasher.html
Old December 16th, 2012, 08:31 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks! I guess the Exmoor mat has some sort of backing that makes it thicker than the factory carpet. Depending on when I get it, hope to be tackling this come late January.
Old December 16th, 2012, 09:43 PM
Bill Larson
Bill Larson
no backing but be careful the way you handle it. If you man handle it it will tear at a seam. Not because its cheap...its just molded and very heavy material so the thinner cutout could seperate. While taking mine out of the box that happened to me.
exmoor
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
