European 7 Round Plug... where to buy? - Defender Source
Old March 18th, 2015, 10:52 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Do you guys know where I can get just the plug? I have the wire and the 4-flat end, just need the plug that plugs into the defender receptacle.
Trailer Wiring Adapter: 7 Way Euro Round To Flat 4 Conversion Plug
I checked with Zack and he said RN doesn't carry it. And most places look like they carry it, but it's really not the European round. Otherwise, I'll just break down and pay the ridiculous AB rate especially since I only need the plug.
The older threads on here that cover this point to stock that no longer exists...
Old March 18th, 2015, 10:57 AM
You need more than a plug. There are diodes in that adapter. European trailers have separate circuits and North American trailer use a single wire for turn signals and brakes. Without a diode, the power will back feed and mess up the vehicle lights.
North American trailers.
European Trailers. you need to join the brake wire to the indicator wires with two diodes rated for the draw of the lights.
Old March 18th, 2015, 11:17 AM
rankar's Avatar
rankar
John thanks for posting this, very helpful, I really appreciate it.
I've got some diodes laying around which I'm sure will cover the draw.
Now if I could just find that plug...
Old March 19th, 2015, 10:54 AM
brdhmltn
Brad
1985 110 2.5NA
12N 7 Pin Replacement Plastic Trailer Caravan Truck Towing Electrics Plug 12V | eBay
You don't have to use that vendor, just a representative link of what to buy. You need a 12N plug.
I've built these for 2 Disco 2's and 2 Defenders, for both flat-4 and flat-5. Easy afternoon rainy day project with the diagrams.
https://www.google.com/?gws_rd=ssl#q=12n+wiring+diagram
http://en.wikipedia.org/wiki/Trailer.../North_America
Even though I have the diagrams, every time I wind up using a voltmeter on the vehicle plug to verify.
I've never put in any diodes and never had issues, but I also built and wired my own trailers. Pulling a reverse light signal for trailer brakes is fun. On my defender I just used the rear fog light and had to remember to turn on the fog lights when backing up my boat.
Defenders spinning round and round tpond Misc. Chit-Chat 17 May 26th, 2014 10:27 AM
European trailer plug to flat 4 harness brn24whl The Vendors Loft 47 August 15th, 2013 12:19 PM
Trailer Connector - 7-Way European Round To Flat-4 Conversion achampagne Wanted 22 August 4th, 2011 08:24 AM
Round clock plug Rugbier Defender Technical Discussions 2 February 23rd, 2011 02:15 PM
European Plate (tag) - Source Kimos Defender Technical Discussions 3 November 10th, 2004 06:42 AM
