Dual shock turret install, HD turret rings - Defender Source
Old March 7th, 2015, 02:53 PM
Installed britpart galvanized dual shock turrets and terrafirma HD turret rings.
The galvanized turrets were painted black to give the galvanizing some additional protection against corrosion.
In pictures...
Worked well in a test. No real differences between standard except:
1. 100x easier/faster to remove/install shocks
2. much easier to retain front springs at top with hose clamps.
3. could potentially allow for front bottom relocation cones, if such things existed.
ID:	115482   Click image for larger version
ID:	115484   Click image for larger version
ID:	115486   Click image for larger version
Old March 7th, 2015, 03:05 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Still have those OEM upper spring retainers I see
Old March 7th, 2015, 03:08 PM
As a note, some web sites have stated that the britpart turrets require modification of the truck.
This was not true on my truck. The install was drop-in.
Others have said that tires can rub on the shock at full lock. I have 32x11.5R16 tires on Freestyles with 50mm spacers and there is no rubbing at full lock.
------ Follow up post added March 7th, 2015 03:09 PM ------
right!
Odd Shock Turret Question Z.G Smaller Projects 2 April 29th, 2014 08:36 AM
Defender shock turret... alastair Wanted 1 June 20th, 2013 01:03 AM
Terra Firma shock towers, short with rings ron For Sale - Parts 12 December 31st, 2012 06:25 PM
Land Rover D90 D110 D130 RRC & DI +2" Front Shock Tower / Turret - NEW JohnC For Sale - Parts 8 November 9th, 2011 08:14 AM
Front Shock Turrets and Retainer Rings Manimal Wanted 3 March 8th, 2011 10:40 PM
