Drum, Hub & Drive Flange paint advice... - Defender Source
Old September 25th, 2017, 09:50 AM
DCG's Avatar
DCG
David
1984 110 CSW 3.5 V8 LHD
I'm restoring the drums, hubs, and drive flanges on my early 110. The hubs are raw metal and the flange is only partially painted (exposed surface). My questions are:
1) Should I paint the inside of the drum (minus the braking surface) to prevent rust?
2) Should I paint the whole hub for rust prevention (minus the internal bearing/race area)?
3) Should I paint the exposed flange surface before assembling or after by masking off the hub cap, etc?
I plan on sticking with my steelies... so the hubs will be exposed. Ideally, I'm interested in ease of maintenance and rust prevention. I don't want to paint something that will cause issues later.
Thanks everyone...
Old September 25th, 2017, 10:17 AM
Naplm00
Matthew
Yes to all, none of this will hurt your vehicle. Will also make it look really nice!
I like using engine enamel on surfaces like this.
When I prepped all my suspension components for painting I used these steps.
Strip all old paint and Rust with a wire wheel on an angle grinder
Coat the entire part in prep and etch or ospho
Rinse off prep and etch and ospho
Completely dry part
Self etching primer
Engine enamel
For the axle tubes I added POR 15 and removed the self etching primer.
All the components look like new even after 2 years in New York and one year here in California
Edit : just noticed that you said inside of the drum. You can do all this if you want but frankly it's not going to matter for that part. It'll probably rust anyway and the assembly tolerances are so large on the rear brakes that if you back the adjusters off fully you can always Hammer off the drums.
Old September 26th, 2017, 12:13 PM
DCG's Avatar
DCG
David
Thanks! This confirms what I was thinking. I saw your "Edit"... if the paints starts flaking inside the drum, I'm not sure I'd want particulate floating around in there. Freshly painted flanges with new bolts sounds like a beautiful thing.
Any recommendations from other members?
advice, paint
Daily Drive Advice New Guy Misc. Chit-Chat 52 October 10th, 2013 01:03 PM
Drive flange RRC front o2batsea Wanted 3 July 1st, 2013 08:37 AM
Heavy Duty Drive Flange Shearpin Defender Technical Discussions 3 May 22nd, 2012 02:41 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 10:51 PM
Paint a fiberglass hardtop? roverboy Defender Technical Discussions 5 December 12th, 2003 08:52 AM
