Door Hinge Repair....Will this work? - Defender Source
Old December 10th, 2017, 10:59 PM
Fred Lobster's Avatar
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Looking at possible ways to prevent future corrosion/rust before I refinish my hinges. Can anyone tell me why this is a bad idea?
Looking at inserting a nylon bushing into the door part of the hinge, that would prevent metal to metal contact between the hinge pin and the hinge, as well as adding small nylon washers between the hinge parts to prevent hinge metal to metal contact.
It requires drilling a little out of the door part of the hinge, to fit the bushing, as well as allowing the center to have a new hole that is not worn out due to years of use.
I'm not sure how long the nylon would hold up...hoping someone might know why this should, or shouldn't work.
ID:	334289   Click image for larger version
ID:	334305   Click image for larger version
Old December 10th, 2017, 11:10 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Buy stainless hinges.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old December 11th, 2017, 12:04 AM
The newest style hinges are galvanized and have bushings.
Old December 11th, 2017, 01:17 AM
rivermike's Avatar
rivermike
Michael
2008 LHD Tdci 110 Keswick Green
And they are cheap to buy, less than $ 17,- each, check link below
Front door hinge - LH top - from WA138480 - Paddock Spares
For LHD Defender restorations and refurbishments
WEBSITE :
EMAIlL :
Current Inventory is listed in my STOCKLIST section
Worldwide shipping is our specialty
Old December 11th, 2017, 06:00 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Ensure you are getting decent hinges. I bought new BritPart and 1 of 4 were sloppy at hinge joint. Turns out UK forums mention this a lot.
You have a nice truck. Would suck to do this twice.
KGH - “Stinky LR diesel” Defender Snob
Old December 11th, 2017, 08:56 AM
non-issue with push button doors but the new style hinges require a little 1/8 trim on two part doors so the cappig clears this style hinge.
Old December 11th, 2017, 09:06 AM
This. The stainless steel hinges have gone way down in price.
Old December 11th, 2017, 06:50 PM
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Looking at Croytec and Offroad Monkeys. Any other recommendations?
Old December 11th, 2017, 07:06 PM
Naplm00
Matthew
Optimil
Old December 11th, 2017, 08:10 PM
https://yrmit.co.uk/product-category...nder-90/doors/
YRM doesn't let Google crawl their website, so you can't see their cost effective stainless hinges in a casual Google search.
I don't think anyone has a lower price.
Old December 11th, 2017, 08:22 PM
There is zero reason to spend money on stainless hinges. The latest OE hinges are galvanized with bushings. They will outlast your truck.
Old December 11th, 2017, 08:29 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
How y'all doing Pete?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 11th, 2017, 08:32 PM
Care to share a source? Without a reliable source, they're not an option.
Old December 11th, 2017, 08:41 PM
Naplm00
Matthew
the stainless look tits tho
Old December 11th, 2017, 08:47 PM
Sorry, what are you asking? A source to buy them? Any Rover supplier. Same hinges from TD5 on. The bodies are zinc plated with plastic bushings on the pins.
Old December 11th, 2017, 09:08 PM
Pretty much the only factory hinge anyone carries anymore. Michael linked one @ Paddocks but universally available.
Old December 12th, 2017, 12:18 AM
Fred Lobster
Pete Gerbine, III
1993 110 (#451)
Thanks for the input, and doing great, Roverman!...hoping the same for you guys!
I'm not quite sure I like the contemporary design of the Optimil hinges, though the do look well built, just not sure if they fit the look of my truck.
The YRM hinges look a little too blingy for my taste, from what I have seen on their site.
I'm not too impressed with the ProLine/Chinese hinges, either.
The Paddock hinges look identical to the ProLine hinges.
I'll look a little deeper at the OE hinges.
Thanks, again, for the input.
Old December 12th, 2017, 07:23 AM
Well, I have four so-called NTO "Puma" Hinges on my truck. They're very different from the hinges that are being sold by the parts companies. They have a plastic bushing,
I've bought two "TD5" hinges from suppliers (not many grant you). They both came with a totally different finish (a shiny electroplated zinc). They also used a brass/bronze bushing.
The NTO Puma Hinges have been rust free for years. The TD5 hinges started bleeding rust months after I painted and installed them. The generic parts supplier hinges are also different in spec than the puma hinges.
So that's why I asked for a specific part number or supplier. Because I have first-hand experience that "Any rover supplier" is incorrect, or at least yields a hinge that is just as rust prone as the original hinges?
Old December 12th, 2017, 09:01 AM
I said to get the OE hinges, not the aftermarket ones.
Old December 12th, 2017, 09:51 AM
tbs78
tom
95 NAS 90 ST
Are there any options for new hinges that don't require a trim of the capping on the st doors? I would love a bolt on solution stainless or puma whatever. I am pretty certain the new td5 ones do require cutting.
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
Repair shops suck. waveridin1959 Misc. Chit-Chat 1 August 18th, 2004 04:00 PM
Brake repair follow up OUCH paulb Defender Technical Discussions 3 December 3rd, 2003 09:19 PM
Custom Work mgrgpg Misc. Chit-Chat 6 November 14th, 2003 08:59 AM
