Depurification of an NAS 110 - The overland build - Page 3 - Defender Source
Old January 11th, 2015, 04:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yep, thats the one I have. GWDL009. Only the door sheet is Alu, the rest is steel and so it's more or less as heavy as the full steel version. A bit misleading I'd say...and pointless. I suspected that the top of the strut needed to swivel 180 degrees but I am afraid to break it. Perhaps they just sent the wrong strut? I'm going to try and disassemble it this afternoon. The head doesn't appear to swivel 180 without disassembly. Front Runner... worse than IKEA.
Originally Posted by Overlander View Post
yep. looks like there was a design change. if you go to frontrunner ZA, pre-07' 110's only have GWDL009 available, which is aluminum. they don't even show a steel version. you have glass or metal door options; not steel vs alu. in the zoom in product pictures of the current 009 model, the strut attaches to door and frame on opposite sides, unlike my 002. so just remove the upper strut attachment and move it to the opposite side, and you should be good.
Old January 11th, 2015, 05:10 PM
those head do swivel 360 deg. I had the head on the wrong side when I first installed then had to look at the pictures to get it right. I couldn't say if my frame is steel or alu. since there's weatherstripping between it and the body, and it's powdercoated, I'm not concerned about differential corrosion. your lower strut mount is more flush than mine, so that's a good thing in my book. that's the only change I see.
Mark Kellgren
KM4BOR
Old January 11th, 2015, 06:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Fixed!
Old January 11th, 2015, 06:26 PM
perfection!
Mark Kellgren
KM4BOR
Old January 11th, 2015, 06:40 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Originally Posted by Rocky View Post
Toysrus has stolen the idea!
This could be Kellgren's new avatar!
Old January 11th, 2015, 06:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Now that the red mist has settled and I have calmed down I'm actually very happy with them. The instructions left something to be desired and the whole aluminum thing is a bit of a misrepresentation but they are great otherwise. Will start sketching on the shelving system next. Thanks!
Old January 11th, 2015, 06:50 PM
I'll consider it when my current avatar isn't relevant anymore...
Mark Kellgren
KM4BOR
Old January 12th, 2015, 05:13 PM
Greenbull's Avatar
Greenbull
Mark Miller
So 2016?
Old January 12th, 2015, 05:34 PM
So 2016?
Changed just for you
Mark Kellgren
KM4BOR
110, nas, nas 110
97 NAS: Garage Queen to Daily Driver/Overland Use. SMac Smaller Projects 143 August 16th, 2014 04:04 PM
NAS 110 Binnacle. Should we build some SafariHP Misc. Chit-Chat 3 November 7th, 2013 11:18 AM
NAS 90 Project NORAD 110 Crew Build SafariHP Truck Build-up's & Restores 37 May 16th, 2012 10:19 AM
Overland Ready Defender 110 TD5 draaronr For Sale - Vehicles 0 June 2nd, 2011 09:58 AM
FS Parts Leftover from NAS 110 Build surf110 For Sale - Parts 32 March 2nd, 2010 11:24 PM
