Depurification of an NAS 110 - The overland build - Page 2 - Defender Source
Old January 4th, 2015, 10:45 PM
RBBailey
RBBailey
1965 IIa
Danngit... I even looked before posting.
Thanks.
Old January 10th, 2015, 11:44 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mark, did you use silicone or other sealant for the installation?
Old January 10th, 2015, 11:47 AM
The Gullwing frame has weatherstripping on the outer face where it mates with the outer body. Instructions call for silicone on inside to further seal. I just sprayed rubber sealant I had from home depot and that's it. Too easy.
------ Follow up post added January 10th, 2015 11:49 AM ------
Rustoleum Leak Seal
Mark Kellgren
KM4BOR
Old January 10th, 2015, 01:57 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sounds messy. I prefer caulk.
Originally Posted by Overlander View Post
I just sprayed rubber sealant I had from home depot and that's it. Too easy. ------ Follow up post added January 10th, 2015 11:49 AM ------ Rustoleum Leak Seal
Old January 10th, 2015, 02:07 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I'm sure you do!!! Sorry I has to say it
------ Follow up post added January 10th, 2015 02:08 PM ------
Damn it! I was first
Old January 10th, 2015, 02:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I couldn't resist. Caulk jokes never gets old.
Mark, the instructions assume the door is separate from the frame but mine came assembled. I assume I've got to disassemble the door from the frame in order to line up and drill holes?
Old January 10th, 2015, 02:52 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The answer is yes
Brett's window is a little different than the FR one.
Old January 10th, 2015, 02:57 PM
Yes. Mine was assembled too. Take that door off. 1 min job.
Mark Kellgren
KM4BOR
Old January 10th, 2015, 03:14 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
This shit's legit.
Old January 10th, 2015, 04:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
First window done. 2 hrs 15 min. Second should go faster.
Old January 10th, 2015, 09:12 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ok. Both windows are in but it appears to me that the gas struts were incorrectly mounted onto the support brackets. Take a look at the attached photo. Shouldn't the top portion of the strut be mounted on the other side of the bracket so that it's more vertical? That's how I would want it but the mount wouldn't swivel 180 degrees. Is this how yours ended up, Mark?
Love it otherwise. Very stout.
Old January 10th, 2015, 11:08 PM
Doesn't look right. Will post a pic of mine tomorrow. And there shouldn't be any black where the nylon nuts are. Did you remove the weather stripping?
Mark Kellgren
KM4BOR
Old January 10th, 2015, 11:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I removed the protective film on the weather stripping that was pre-installed. There was no weather stripping inside the windows that I had there before. Not exactly sure what you're referring to but I can take a better photo tomorrow with it open.
Old January 11th, 2015, 10:54 AM
This is what right looks like.
Attachment 110641
Mark Kellgren
KM4BOR
Old January 11th, 2015, 11:50 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
This is what mine looks like open. Your door looks different than mine.
Old January 11th, 2015, 12:14 PM
it's not the door or the frame, the difference is in the lower strut bracket that bolts on using the 3 vertical frame nuts on the left. mine comes out (projecting toward the center of the windoow) farther to line up the strut. not sure why they would be different from mine coming from the same supplier and time period. are you having any issues opening or closing?
Mark Kellgren
KM4BOR
Old January 11th, 2015, 01:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It works fine but I am concerned they may have sent me the steel version instead of the aluminum. Will check this afternoon.
Old January 11th, 2015, 01:51 PM
Toysrus has stolen the idea!
ID:	110650   Click image for larger version
Old January 11th, 2015, 02:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
They sent me the steel version even though I ordered the aluminum version. Not happy. Boxes were not labeled.
Old January 11th, 2015, 04:41 PM
yep. looks like there was a design change. if you go to frontrunner ZA, pre-07' 110's only have GWDL009 available, which is aluminum. they don't even show a steel version. you have glass or metal door options; not steel vs alu. in the zoom in product pictures of the current 009 model, the strut attaches to door and frame on opposite sides, unlike my 002. so just remove the upper strut attachment and move it to the opposite side, and you should be good.
Mark Kellgren
KM4BOR
110, nas, nas 110
97 NAS: Garage Queen to Daily Driver/Overland Use. SMac Smaller Projects 143 August 16th, 2014 04:04 PM
NAS 110 Binnacle. Should we build some SafariHP Misc. Chit-Chat 3 November 7th, 2013 11:18 AM
NAS 90 Project NORAD 110 Crew Build SafariHP Truck Build-up's & Restores 37 May 16th, 2012 10:19 AM
Overland Ready Defender 110 TD5 draaronr For Sale - Vehicles 0 June 2nd, 2011 09:58 AM
FS Parts Leftover from NAS 110 Build surf110 For Sale - Parts 32 March 2nd, 2010 11:24 PM
