Delicate front door windows - Defender Source
Old April 24th, 2016, 11:21 AM
samjone
Sam Weirich
1990 110 SW
Does anyone have a fix for front door windows that come out of the window channels if the door is shut too forcefully. Having taken the door apart I found that the front edge of the window popped out of the vertical channel and actually stripped the two screws holding the channel to the aluminum shim attached to the door. Seems like a fragile arrangement. Any suggestions other then don't slam the doors closed with the windows down?
Old April 24th, 2016, 11:24 AM
ssi19's Avatar
ssi19
scott
1995/D90
Please post pics. Hard to help without.
Old April 24th, 2016, 12:28 PM
Matt223081's Avatar
Matt223081
Matthew Scanlon
84 D90 200TDI
I cut an aluminum square bar in half, lined it with felt and pop riveted it in the old hole location. Crude but it kept the window from popping off the track
'06 Discovery 3
D90 trail truck project
Old April 24th, 2016, 12:30 PM
samjone
Sam Weirich
1990 110 SW
Here are two shots. One is of the upper section of the window channel and the other the lower section. One can see that the lower section of the window channel has pull free of the aluminum shim as the only screw there has stripped out of the channel. I thought of placing some adhesive between the shim and the channel and placing a larger screw through both but the screw head will block the window from rolling down completely. Open to any suggestions.
------ Follow up post added April 24th, 2016 09:32 AM ------
Seems my photos are now downloading. Hmmmmm
Old April 24th, 2016, 12:32 PM
samjone
Sam Weirich
1990 110 SW
------ Follow up post added April 24th, 2016 09:34 AM ------
I downsized them to 134 KB on my MAC and can drag them over into the message box but they are not transmitted. Rookie at this. Must be another way...
Old April 24th, 2016, 12:55 PM
Below the post box is "Attach Files", click on the "Manage Attachments" button. You can't drag and drop files to a forum.
Old April 24th, 2016, 04:36 PM
samjone
Sam Weirich
1990 110 SW
OK. Lets try this. Top shot is the upper aspect of the window channel and bottom shot is the lower. There are only two small metal screws holding the channel to the aluminum shim to the door itself. Kind of a flimsy arrangement.
Old April 24th, 2016, 04:37 PM
samjone
Sam Weirich
1990 110 SW
Er... that would be left sot is top of channel and right the bottom. I'll get the hand of this...
Old July 5th, 2016, 11:28 PM
discodaze
ian tydeman
1969 Rover Hybrid SWB,
Did you ever find the fix to this? Mine is doing the same and I see we live in the same town.
1992 Defender 110
1983 stage one v8 109
1995 disco
1969 88 hybrid
1967 88 work in progress
1957 Series 1 swb in boxes
Small addiction
door, window, windows
WTB:Hardtop side WITH windows 110 2 door brn24whl Wanted 6 July 21st, 2010 03:17 PM
Soft-top door windows d90boy Wanted 2 July 20th, 2006 05:47 PM
door and windows bjenk Defender Technical Discussions 7 May 9th, 2005 10:08 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
Door Windows on '97 D90 Rob Defender Technical Discussions 4 November 3rd, 2003 04:11 PM
