Defender fuel pump access door - Defender Source
Old April 18th, 2016, 08:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
For those who have already done it, post up some pictures, suggestions, etc.
Rent my
Old April 18th, 2016, 08:35 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
I've got a few photos somewhere of those I have seen, best one I've done was just a round aluminum plate from some kind of electrical box cover about 10" across. Rent a giant hole-saw bit, cut, paint cover to match, add arbo around the perimeter, and rivet in place. Easy to drill a half-dozen rivets when the pump fails, doesn't rattle loose, or rust, and looks factory enough to not be obvious with no metalworking skills needed...
Old April 18th, 2016, 08:48 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Not finished yet, but here is the beginning of what will be open access between the supports. I originally was planning on a hatch but I'm starting to think it might make sense to be able to remove a wider section of the floor panel so I can access the fuel lines as well.
ID:	147599   Click image for larger version
Old April 19th, 2016, 08:19 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Good suggestions so far.
I'm also thinking of using a RRC fuel pump trap ddor that I have....
Rent my
Old April 19th, 2016, 09:52 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've cut out a round hole and used D1/D2/RRC access covers. Downside is a slight rise in the floor mat, ie no longer a flat floor.
Email is
Same place, new dogs.
Old April 19th, 2016, 09:58 AM
Why bother? Its pretty quick to pull the fuel tank out to do the pump, and its not like you are going to be replacing the pump on a regular basis (unless you are Josh).
Old April 19th, 2016, 10:02 AM
Awesome considering the thread I just started hahahha
Old April 19th, 2016, 10:04 AM
Why bother?.
For when there are fueling issue on the trail. It allows an easy inspection to troubleshoot, avoiding a 5 day walk back to civilization.
Old April 19th, 2016, 11:56 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Because...you know the pump will fail at the worst place on some trail or remote area....it will NEVER quit in my driveway OR when the tank is close to empty! LOL
Rent my
Old April 19th, 2016, 07:42 PM
Using that logic I need to great spring access hatches, quick release shock mounts and quick disconnects for anything electrical.
Old April 20th, 2016, 03:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Brilliant!!
Oh, but most everything electrical already has quick disconnects....
Rent my
Old April 25th, 2016, 10:43 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
This got me thinking so I used the RRC fuel pump door but I flipped it.
I peeled all the gasket material off, restuck it on the opposite side so the hump goes down.
Kept the floor flatter.
ID:	148046   Click image for larger version
ID:	148048   Click image for larger version
Rent my
Old April 25th, 2016, 10:56 AM
Great another place for water to leak in (and out)!
Old April 25th, 2016, 11:25 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
What size hole did you need to cut for this? Looks clean
Old April 25th, 2016, 11:39 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Not exactly sure of the hole size.
I started with the RRC door and just made the hole smaller.
Leaving enough metal to put some small rivnuts in for the door to screw into...
I just jigsawed it---it cut pretty smoothly.
Then I went back and Dremeled the edges to debur them.
Rent my
Old April 25th, 2016, 11:41 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Just wondering if the door would be an appropriate size for access to my newer tank. This is a lot less
Work than what I was planning.
Old April 25th, 2016, 11:56 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Hmmm..that's a good question.
My project is suitable for a NAS style 90 with rear fuel tank.
I measured twice, cut once. OK, I measured more than that...but I had to make sure the hole was centered directly over the fuel pump.
I only lost one small section of floor support and you cannot feel it at all.
Rent my
Old April 25th, 2016, 12:06 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'll have to track down one of these doors and get the dimensions and see if it's a big enough opening to pull the pump out. I have the exact location I need (mines offset).
Old April 25th, 2016, 12:08 PM
Allbrit.de - Ersatzteile fŁr LAND ROVER & MG ROVER
MXC1420
Old April 26th, 2016, 11:01 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Jimmy, I failed to mention that I put a brand new pump in the tank....almost a guarantee that I'll need to change it out in a year or so!
Rent my
ac, defender, door, fuel
Aluminum 90 floor with fuel pump access! Ash Defender Technical Discussions 19 November 24th, 2015 12:27 PM
New various Rover dash, grille, rear and fuel access labels - For S HeloBubba For Sale - Parts 4 January 14th, 2013 10:05 PM
clutch access door into fender URL? Gkase Defender Technical Discussions 10 April 29th, 2010 03:28 PM
How to access Bulkhead Door Hinge Bolt Fixed nut bd90 Defender Technical Discussions 15 April 8th, 2010 01:44 PM
RR Classic Driver's Front seat bottom access door jack frisch For Sale - Parts 0 February 27th, 2005 01:50 AM
