Defender 200Tdi refresh - Defender Source
Old June 10th, 2015, 02:06 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Thought I would put up some photos and words to my head gasket project that turned into a head refresh. The engine was purchased from a shop down in Atlanta so I never recieved any info on its milage or service history. With that in mind and some blow by concerns I decided to replace the head gasket, replace a few old hoses, new fan clutch, remove 2lbs of RTV, and inspect every damn bolt. I found heavy carbon buildup about halfway up on push rod #8 which I believe is a known problem area on these engines (but I could be wrong). Found a few missing bolts/studs. I replaced all of the springs, retainers, gaskets, seals, studs, and most all of the nuts & bolts.
Head off,
All 8 retainers were in need of replacing.
Tearing down the head
all organized. Definitely went overboard but a little OCD never hurt.
Nice and skimmed.
Rebuilt ready for action
after a 650mi trip up to Maine, no issues to report.
Old June 10th, 2015, 02:10 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Great work Andy,
did the same with my replacement motor from that place in Atlanta... but did not take the head off as it had 410psi of compression/cly.
Lets see how long that lasts.
Old June 10th, 2015, 02:15 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Good job and great pictures.
You can easily view the thin bridge between the intake & exhaust vales in the skimmed photo.
It is easy to understand why that thin strip of material often cracks.
RDavisinVA
Old June 10th, 2015, 03:54 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Well done!
The bridge between inlet and exaust valve is a litte bit thicker at the 300tdi head.
But it cracked sometimes to the bore of the injection valve.
Do you changed the thin shims beyond the valve springs too?
The seats are refreashed I hope.
Old June 10th, 2015, 06:12 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Thats a very nice looking head! and I like the tray. I didn't replace the shims as they looked and felt find. I could only find the 300TDi part number. Anyone know the 200TDi one?
Old June 10th, 2015, 06:25 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
It's a new one!
http://www.defendersource.com/forum/...tml#post572248
200tdi, defender, tdi
Transceiver Refresh Bill Larson Misc. Chit-Chat 13 April 29th, 2015 07:51 AM
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 05:20 PM
Proper Defender high-turbo 200tdi Defender diesel enigne for sale (Gearbox too) ZombieMotors For Sale - Parts 1 August 19th, 2013 12:02 PM
Refresh me on the issues with 35's btate Defender Technical Discussions 15 September 12th, 2006 07:35 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
