Defender 110 Fuel Tank question - Defender Source
Old October 16th, 2011, 02:32 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Afternoon
Just had a leak in my steel 110 fuel tank repaired locally. They applied a thick sealant after the repair and now the tank doesn't appear to sit perfectly in the tank's cradle. I filled it with diesel today and I am sure the weight will settle it back into the cradle.
A quick question... the fuel return line at the leading edge of the tank - near the two rubber insulated bolts - is really close to the cross member above. The photos were taken laying on my back looking up at the leading edge of the tank. The return line sits really close to the cross member and at the moment and the rubber insulated bolts aren't very tight. Anyone know if the return line should sit above this cross member, rather then below? If I snug the bolts up the return line and cross member will be in contact - with some pry bar work I can probably squeeze the return line above it.
Regards,
Henry
ID:	42795   Click image for larger version
Old November 6th, 2011, 03:19 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'd put some spiral protecting plastic wrap around anything that looks like it might rub.
Mike Hammond
110, defender 110, fuel, fuel tank
110 Fuel Tank Removal moose Defender Technical Discussions 13 February 7th, 2015 11:35 PM
'84 300 Tdi 110 Fuel Tank Shearpin Smaller Projects 3 September 1st, 2011 09:02 PM
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
1993 Defender 110 mpodgorski For Sale - Vehicles 11 April 4th, 2006 07:07 PM
Wanted 2004 Defender 110 boshea Misc. Chit-Chat 24 February 19th, 2005 10:56 AM
