Dash Radio Mount - Page 2 - Defender Source
Old May 7th, 2016, 07:55 PM
LakeLBJ
CC
SOLD - 1987 D90 LHD / 200TDI
Here's my setup. Has USB power and DC power adapters. Lots more spaces for switches. Basically, the shifter gets in the way of everything.
Old May 7th, 2016, 08:21 PM
kurtisblo's Avatar
kurtisblo
Kurt
1991 Defender 110, LHD 200TDI
Thanks for the photo. I definitely just want a small, slim mounting device. I found this one but i can't tell if it is the same color (light grey) as the top portion of my dash.
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Old May 7th, 2016, 08:56 PM
LakeLBJ
CC
If you can figure out the part number, see if LRDirect has it as they will be 1/3 the price of Roversnorth or Atlantic British.
Old May 7th, 2016, 09:19 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I assume you know this, but be careful with that grey plastic middle section(LHD) as they are unobtanium...
Rent my
Old May 7th, 2016, 09:29 PM
phoenix37's Avatar
phoenix37
john
AWR2277LOY | Housing Radio - Paddock Spares
or you could do one of these. My 110 came with something similar.
http://www.crutchfield.com/p_1209990...7550265&awdv=c
Old May 7th, 2016, 09:36 PM
kurtisblo's Avatar
kurtisblo
Kurt
I assume you know this, but be careful with that grey plastic middle section(LHD) as they are unobtanium... .
I do not. Please tell me more. No one makes them? Can you buy ROW dash replacements?
Old May 8th, 2016, 01:42 AM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
We are putting down acoustic carpet throughout the truck and will put matting over that. I am considering doing dynamat under the carpet, headliner and doors. That would cost around $1500 which seems expensive to me and not sure if that is overkill. Anyone have advice on this? Worth doing the dynamat?
I've done it in a couple of my LR's. Spent $1k on the 71 IIA to eliminate the rattling feeling and was well worth it. Spent the same amount on a 95 RRC SWB that is a parts car now and it made a small difference, but I would say it wasn't worth the time and investment. I do really like the Dynamat under hood insulation for engine noise and you know it's working when snow only melts in the couple of areas you missed. What I also use in my 90'sa and Series trucks is the Exmoor Black Moulded Matting System; Pricey but a quality product and a perfect fit.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old May 8th, 2016, 09:27 AM
Roverbill
William Ruttan
1997/Defender 90SW
Originally Posted by Naplm00 View Post
I have a row truck as well. Was not a fan of the dash radio options, I ended up buying a tuffy box instead and removed the center seat.
I still have the original center console radio location but it is very distracting to have look down there to tune the radio while driving.
Old May 8th, 2016, 11:03 AM
interesting, i do not have major interference from the shifter
radio, dash, mount
Radio mount Abrooks Wanted 3 December 2nd, 2011 09:49 PM
Where to mount Satellite Radio Antenna on ST? KKilo23 Defender Technical Discussions 13 May 18th, 2010 08:44 PM
FS: Genuine Radio Mount Panel fleabus For Sale - Parts 2 April 26th, 2010 01:57 AM
radio wiring harness adapter for aftermarket radio mightymg Wanted 8 March 25th, 2010 02:56 PM
Wanted '97 Switch/Radio Mount Assy. Stmpede Wanted 7 December 10th, 2007 04:38 PM
