dash mounting the radio - Defender Source
Old September 15th, 2006, 03:06 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
So, you get the dash mount plastic kit and then...
Hook ups are antenna, power, speakers. Anything else?
What is the best way to transfer the hook ups from the center?
Should you run everything with extensions under the rubber floor mats and up behind the dash and can you even do that? Are there kits needed?
Old September 16th, 2006, 08:09 AM
btate
Bryan Tate
d90
When I wired my 110 I ran all the wires down to the fuse box (there is a channel behind the dash)
from there its your call. I had no wires at all, so some speaker wires were tucked in under the dash to the front doors.
I rigged some and strung them underneath like a Christmas tree lights....
Riggy, but its just speaker wire....worked fine. Same with sub wires, under the body
If you are going to tap into the harness that is under the tranny cover you may can run the wires over the tunnel but under the mat?? You can use your old wiring harness or tap in direct.
I tried to use the old harness, but the connections were corroded. So I had a stereo store fix it when the made a new sub box and added an amp.
Old September 19th, 2006, 10:36 PM
Cut and splice all the wires, wrap them good so they don't chafe and run them under the mat or under the floor and back up the firewall to the new spot. It took me several stressful hours of soldering and swearing to do this project. Beer would have made it a lot easier. I had a 97 and it was a pain in the butt to make it all fit into that little box. A 94 will be a lot easier because you don't have the dome light module to move. I think I needed about a 3 foot antenna extension.
dash, mount, radio
dash mounted radio console bharris Wanted 21 March 22nd, 2017 10:40 AM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Dash install of radio paulb Defender Technical Discussions 3 December 17th, 2004 05:42 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
