D90 bolt on upgrade projects - Defender Source
Old July 10th, 2015, 11:15 AM
stevieweevie
Steven Fudge
1987 Defender 90
Hi all,
Thought I'd post my D90 that I'm trying to build up. Its my first LR and its great fun so far. Probalby will never be a show vehicle and unlikiely I'll do a frame off resto on it but want to upgrade it and maintain it for form and function. I like to take it on local trails so moderate off-road capability is key for me, stock isn't good enough for what I like to do and has unfortunately left me low and wet...
Pics attached of how it was when I originally purchased it -
Have recently added following, with more to follow -
ARB front / rear lockers
Terrafirma tube bumper with grill guard
HF 12k Winch
More aggressive tires
Next on list -
Rock Sliders
2 in ome lift
offroad light upgrades
ID:	124701   Click image for larger version
Old July 10th, 2015, 11:28 AM
stevieweevie
Steven Fudge
1987 Defender 90
Tire Upgrades
Purchased some retread tires from TireRecapers in TN and they worked awesome offroad even with full air pressure. Cheap - 500 bucks after tax and mounting
ID:	124703   Click image for larger version
Old July 10th, 2015, 11:36 AM
stevieweevie
Steven Fudge
1987 Defender 90
Bumper Upgrade
Went with the Terrifirma bumper, seemed to be the best pricing i could find for what I was looking for. Would like to get a skid plate style steering guard protector in the future to ad to this. I think the look of these is pretty tough along with the actual protection.
Went with HF 12k Winch, I know HF doesn't have the best reputation with long life but I did add the warranty to this and for $300 bucks it was hard to find something else that will makes more cents...
ID:	124706   Click image for larger version
ID:	124708   Click image for larger version
ID:	124710   Click image for larger version
Old July 10th, 2015, 11:43 AM
Kidzvillage's Avatar
Kidzvillage
Luis Beltran
It looks great! are you doing the conversion by yourself? how about the power to the winch?
from the standard bumper to the Terrafirma, is it a bolt on replacement?
Old July 10th, 2015, 11:49 AM
stevieweevie
Steven Fudge
1987 Defender 90
Thanks a ton! I love the truck and am excited to get these things installed.
I had the ARB lockers installed by a local shop, that's probably a little out of my tool box and capabilities / confidence but they did a great job for good price - relatively speaking. Those things are expensive!
Did the bumper / winch myself yesterday. All wired up and functional. Going to try and pull something with it today. . Thinking the pulling giant 20 year antenna dish in the back yard out of the ground ha.
Bolt on replacement, no special tools or cutting / welding required. Needed additional length for power cable since D90 battery is in cab rather than engine bay as most jeeps are, otherwise would have come with enough wire from winch in box. Has circuit breaker with kit as well. I did purchase 50ft wireless remote and permanently mounted to bumper by drilling a couple of holes.
Old July 10th, 2015, 12:02 PM
Kidzvillage
Luis Beltran
Wow! it is looking great!, I will start my plans to do the same,
Old July 14th, 2015, 03:19 PM
stevieweevie
Steven Fudge
1987 Defender 90
Rock Sliders
Added some Rock Sliders over the weekend from Rovers North. These are the Rovers North branded versions. These were kind of a pain in the ass because of rusted on bolts for me but finally went together in the end. The caked on mud didn't make things any easier
Had some help from this video which shows how to install this particular brand of slider -
Id add to the tool list for this video a big hammer with 2x4 to help "ease" the rear bracket into the outrigger hole. Mine was no longer perfectly round so the rear bracket took some encouragement to make its way into the hole. I also needed to get some large washers to use as spacers for the front bulkhead bolt to get the slider centered front to rear of vehicle. Also needed to let the front bulkhead bolt soak with PB Parts Blaster to remove to prevent stripping the bulkhead bolt off. That was a pain because of whoever removed and rigged it up last.
Hope to install 2" OME lift next weekend
Last pic is my "test run" of the winch Pulled an old satalite dish from the ground. Might try using snatch blocks next time or cut the wire down, it was super long and got a bit tangled wrapping back up but the winch does have a tensioner to help spool it back a little better.
ID:	124977   Click image for larger version
ID:	124979   Click image for larger version
ID:	124981   Click image for larger version
90, d90
Next projects starting... Gardner Smaller Projects 2 December 3rd, 2010 07:10 PM
ECR Backed Up on projects BEIS Misc. Chit-Chat 16 August 10th, 2008 07:49 PM
Projects for the Weekend Tim Scully Defender Technical Discussions 6 January 9th, 2007 11:12 AM
So what's on the list of projects for this year? Hans Misc. Chit-Chat 15 March 13th, 2006 05:52 PM
More Rover Projects TDI Guy Misc. Chit-Chat 29 November 17th, 2003 04:48 PM
