D90 #497 Noise Reduction Project...!!! - Defender Source
Old September 13th, 2010, 09:31 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ok, so the first project with this great truck is to reduce the noise...(my ears have finally stopped bleeding from the co. trip). I am currently installing Dynamats EXTREME sound reducing pads. Have to say I thought they would be thicker! Starting in the cargo area. Not too much of a problem...yet!
ID:	31033   Click image for larger version
ID:	31035   Click image for larger version
Old September 14th, 2010, 07:11 AM
Does the dynamat have a tendency to hold moisture?
Old September 14th, 2010, 08:50 PM
Bill Larson
Bill Larson
I dont belive it would...it's a tar like substance with foil backing. The thing I like about it is the seams will meld together on there own even without the tape you can buy from them. I have the rear cargo area done 3/4 th's of the way and it really helps. I'll finish the rest of the cargo by the weeks ens and start the front the weekend after. The down side is this stuff isn't cheap!!
Old September 14th, 2010, 08:59 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
It doesn't, only the hoodliner version does.
Old September 14th, 2010, 10:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I'm doing a similar project but concentrating on the front seat area and doing it more for heat as my truck is a ST. Will be interested in seeing your final verdict on the effect. Where are you buying the Dynamat? This stuff gets pricey!
Old September 14th, 2010, 10:18 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Does the Dynemat keep the heat down as well as noise from the footwells? I've been thinking about heat reduction up there. I thought some people had good luck with foil backed acoustic mats.
Old September 15th, 2010, 06:26 PM
Bill Larson
Bill Larson
I'm buying it from their web site. It was shipped really quick.
------ Follow up post added September 15th, 2010 06:29 PM ------
I think it will reduce the heat but I havent made it that far yet. It does reduce the noise in the cargo area. I'll keep posting updates as I go...
Old September 15th, 2010, 06:52 PM
SeattleRRC's Avatar
SeattleRRC
Woody
1990 RRC SWB, 1994 D90 ST
Jeff, I want a ride in your truck when you're done to see the difference Dynamat makes!
Trapping moisture in the footwells was my biggest reason for not using this stuff.
Old September 15th, 2010, 07:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
I did my doors and tub. I didnt do the footwells as I was convinced it would be wet and gross. I can't tell the difference other than the doors sound like a german car now
Old September 16th, 2010, 01:59 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I can't verify in the Rover but I did the entire floor of my '69 Mustang that has long tube headers that basically stop right beneath your feet and it made a huge difference in both interior noise and heat.
Woody, I hope to have it all done by the October HH so you can check it out
Old September 17th, 2010, 09:13 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
sound proofing
I used foil faced, self adhesive, heater duct wrap. It is about 1/8" thick closed cell foam. Installed under hood, doors, under floor mats, seats, behind dash, rear tub & sides under rubber mat, basically everywhere that I could not see the material after installation. Big difference in heat & sound; panels have a "thud" when knocking them. I hose out the 90 regularly...closed cell foam does not hold water. The only problem so far (1 year) is that the foil face has peeled slightly (very thick material) when I hose out under the hood. Best part; Lowe's carries it at about $15 roll, I think I used 4 rolls total. I also replaced the vinyl under the seats with grey outdoor carpet, cut to match, using heavy duty carpet tape...love it, as it dries out quickly.
good luck
ID:	31190   Click image for larger version
90, 97, d90
My new D90 and first project - shift knob advnirvana Smaller Projects 1 May 25th, 2009 08:56 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
