Custom Windshield Soft Top Channel - Defender Source
Old March 20th, 2008, 07:42 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
For all you cheapskates like me who don't want to spend $350 on a chunk of aluminum to mount your soft top, bikini or safari tops to, check out my solution. This simple design would need some tweaking if you wanted to use it with a soft top as I imagine it might leak on the outer edges since it doesn't curve down at the ends.
I used some 3" flat stock and some 1-1/4" angle. I used the plasma cutter to trim off about 1" of the angle iron to make it an "L". Then the two pieces were welded together and holes drilled to mount it in the stock threaded holes in the windshield. Total time was about 2 hours including paint drying time, and total cost was $30 for materials.
ID:	12737   Click image for larger version
ID:	12739   Click image for larger version
Semper Fi!
Old March 20th, 2008, 09:16 PM
Sweet! Just what I need for Janey. Can you bring one by on Saturday?
channel, soft top
Soft Top Header Rail / Windshield Channel e90miller Wanted 0 August 6th, 2009 07:32 PM
Soft Top Header Rail / Windshield Channel Wolf Fabrication For Sale - Parts 0 June 7th, 2008 04:34 PM
Soft Top Windshield Channel Wolf Fabrication Wanted 3 March 17th, 2008 09:50 AM
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Need ST channel for top of windshield Method PHX Wanted 1 October 25th, 2005 01:15 PM
» Defender Registry
Maggie
rankar
Blue
dmarchand
Add your Defender
