Custom Roof Rack Fabrication - Defender Source
Old April 12th, 2009, 09:11 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I really wanted a roof rack so I could carry all my gear and still have room in the back for my son or my dogs. I don't care for the Safety Devices or Urban Offroad racks as I think they look like giant shopping baskets. They are also poorly made with pinch welds and utilize weak mounting points on the aluminum body. Those two rack designs also require modification to mount roof top tents. So I came up with my own design - open in the front so I could fit a 1.2m tent - and much more stout in terms of welds and mounting. I sourced 1 1/2" steel tube and 1" steel box and used stainless or grade 8 hardware where needed. For the two front support bars, I went to Rock Hard 4x4 for some 1 3/4" fabrication collars. Total cost in materials was about $300, but I did get a smokin' deal on the steel. As for labor, it was a kick in the balls - a full 3 1/2 days of labor, or about 30 hours of fab time.
Below are a few pics, and you can check out the full write-up here:http://www.cj-3a.com/fabricating_a_custom_roof_rack.htm
ID:	18736   Click image for larger version
ID:	18738   Click image for larger version
ID:	18740   Click image for larger version
ID:	18742   Click image for larger version
ID:	18744   Click image for larger version
Semper Fi!
Old April 12th, 2009, 10:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
Basket is awesome. Similar to ECR. Not sure I like the ladder but your work in general looks great. I need you to live closer to make my basket like this.
Old April 12th, 2009, 11:35 AM
Wolf Fabrication
Sterling Archer
'08 D3
What specifically don't you like about the ladder? The reason I ask is that I may be making a bunch for sale.
Semper Fi!
Old April 12th, 2009, 12:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
The mounts are good. I wish the ladder shape looked like the safety devices one.
Old April 12th, 2009, 12:32 PM
Wolf Fabrication
Sterling Archer
'08 D3
Hmmm... I thought mine was pretty close to the SD ones. My difference is the degree of bends. You'll notice that around the license plate where my curves are not as tight. Here's a pic of an SD ladder below.
Semper Fi!
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
that looks good. I like it because it doesn't look like it is trying to totally copy the SD rack but has its own characteristics too. nice thick tubing and the ladder is cool in its own way.
I didn't like the urban offroad rack because it was trying to do an straight copy of the SD rack but some of the bends were a bit off. This feels more like its own creation and I like that.
I would maybe suggest that the rack is lowered an inch or two. it looks like the crossbars raise it an inch too high. but that could just be the look because no soft top or hard top is on the truck in the photos.
Old April 12th, 2009, 12:38 PM
Wolf Fabrication
Sterling Archer
'08 D3
Good point! I wanted my rack to be as low as possible, so it sits just 1" above the hard top (fiberglass). I think it just looks higher because the top is off. My other option was to angle the basket down up front, but that would have made mounting a tent harder.
Semper Fi!
Old April 12th, 2009, 02:15 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Did you think about relocating the center mounter break light to the rack? I was thinking a bar across the ladder section with a mounting plate right at the hight of the cage piller so not to obstruct view.
Old April 12th, 2009, 02:47 PM
Wolf Fabrication
Sterling Archer
'08 D3
Interesting idea! But to me, the rack is not a permanent addition to the vehicle. I'd remove my 3rd brake light entirely before I moved it.
Semper Fi!
Old April 12th, 2009, 03:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
I think if you made the first step on the ladder more square I would be down with it
Old April 12th, 2009, 03:04 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, that's a tough one as my die is 5.5" center line radius. The SD racks look to be 3.5" CLR. Point taken though as I wish it was more square as well.
Semper Fi!
Old April 12th, 2009, 04:33 PM
I just don't like how the bottom step on the license plate side is basically a half circle. The rest works pretty well, but that's just a strange shape in that location.
Old April 12th, 2009, 04:40 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, that seems to be the consensus, but my die can't get a tighter bend, and I can't make it wider to alleviate the half circle. I do have some pre-bent tighter corners (used for stair railings) that I might be able to splice in. Or suck it up and buy a tighter CLR die.
Semper Fi!
Old April 12th, 2009, 05:16 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Wow, I've seen that rack design before, let me think......it'll come to me......oh yeah..ECR
love the originality.
What tree?
Old April 12th, 2009, 05:25 PM
Aw, c'mon Carey - his ladder is his own design, and a few of us have been doing the 3-sided custom rack thing for a while now. Dave M was the first I knew of, and I did pretty much the exact same thing.
Old April 12th, 2009, 05:37 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
OK, OK,.... I'm not bashing anyone here, but he just stated that it was HIS design, rear ladder-YES, rack-not so much.
What tree?
Old April 12th, 2009, 06:13 PM
There's just not too many directions to go with the basket.
I think you definitely need to use those pre-made bends for the bottom of the ladder. As it, it obscures the license plate.
Wolf Fabrication
Sterling Archer
'08 D3
I said I came up with my own design. Open in front. Mine differs from ECR in that I added more floor support so I wouldn't have to install some type of flooring like on ECRs. So mine is different than ECR in that way. And who gives a #$%@ if mine is an ECR ripoff? They have a great design! Plus there are not too many other styles of baskets out there to do - full basket, or open in the front or back. Not sure what else you could do?
Semper Fi!
Old April 13th, 2009, 09:16 AM
JRW's Avatar
JRW
94 D90 ST #1247
Little off topic, but how tall is your garage door? I really would like to get a rack, but I am not sure I could get it back in the garage...
Old April 13th, 2009, 09:23 AM
Wolf Fabrication
Sterling Archer
'08 D3
Completly on topic! I have 8' garage doors. My D-90 with the rack is 7'2" tall. That's with a 2" OME lift and 285/55 tires.
Semper Fi!
ac, rack, roof, roof rack
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
roof rack swap RiMiD814 For Sale - Parts 2 March 5th, 2006 12:04 AM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
ISO: ANY PARTS for NAS safety devices roof rack NASD90 Wanted 3 February 28th, 2005 01:22 PM
FS/FT RoversNorth roof rack Hans For Sale - Parts 6 May 8th, 2004 07:22 AM
