Custom rear speaker panel above rear door - Defender Source
Old August 20th, 2016, 11:11 AM
poonstar
Vincent
1997 Defender 90
So after looking around for speaker placement options I decided to build my own panel based on some other users on this forum. I didn't want place the speakers low using a MUD panel behind the seats. This panel will replace the rear door headliner panel piece and bolt into the existing places with t-nuts and bolts. Made this in under 4 hours and just need to get it wrapped up at the upholstery along with my custom centre console. Let know what you guys think or suggestions I can make it better.
------ Follow up post added August 20th, 2016 10:13 AM ------
Old August 22nd, 2016, 01:24 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Looks good. What size speakers are you going to use?
Old August 22nd, 2016, 02:42 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
I'd like to see it installed.
Old August 22nd, 2016, 03:14 PM
Nice had you seen the speaker panels another board member has been developing?
http://www.defendersource.com/forum/...ers-68865.html
Old August 22nd, 2016, 03:18 PM
Do you not have air exit vents in the center?
Old August 22nd, 2016, 11:20 PM
poonstar
Vincent
1997 Defender 90
Finished wrapping the panel tonight. It was my first time wrapping so it's not perfect. I will be swapping the bolts for nicer ones to finish it off.
------ Follow up post added August 22nd, 2016 10:22 PM ------
Not in the original panel. There are no vents or insulated panels in the rear cab. I will be getting panels shortly and installing dyna mat. The centre has two grab handles and nothing else.
------ Follow up post added August 22nd, 2016 10:28 PM ------
I saw the pics on google but not the forum. It's a very similar except I want to make mine look like one following piece instead of sections looking like it was layered. My DIY project cost: $31 for marine vinyl, $13 for glue, $25 for wood was from left overs from previous projects and $5 for hardware along with 3 hrs of my time messing around.
Pretty happy with the results so far.
------ Follow up post added August 22nd, 2016 10:29 PM ------
These are Hertz Hi Energy 5.25" coax speakers.
door, rear door
another set "ST bars above door" hlamar For Sale - Parts 5 August 2nd, 2010 01:09 PM
ST bars, above door aosias For Sale - Parts 2 August 1st, 2010 04:37 PM
Wanted: Roll cage above door part dbj2003 Wanted 2 June 17th, 2009 04:25 PM
Header Bar & Above Door Pieces bgamej Wanted 2 January 24th, 2007 04:07 PM
Gap above rear door andyrad Misc. Chit-Chat 7 January 14th, 2007 02:58 PM
