Custom dash for RHD to LHD conversion - Page 4 - Defender Source
Old April 1st, 2014, 11:22 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Grr.... minor setback, the later TD5 instrument binnacle won't fit the brackets for the older type. The LED warning module is slightly longer & hits the lower mounting bracket.... a quick redraw needed.... hooray for CAD
Also got the D1 grab handle.... not as 'chunky' as I remember them..... umm.... wonder if I can find a different one.... any suggestions ?
Old April 1st, 2014, 02:00 PM
Archbronco
Josh
1983 Land Rover 110
The dash is looking good. I am looking forward to seeing the completed concept.
Old April 2nd, 2014, 04:01 AM
Bolson
Ben Olson
1995 Defender 110
Hey Andy......... try these guys ( in Port Coquitlam )http://www.faucher.ca/0942_Stainless...ab_Handle.html
they have all kinds of neat stuff
Old April 2nd, 2014, 07:23 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Awesome thread, can't wait to see this finished up
Old April 3rd, 2014, 09:29 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks.... think the large is a bit too big & the small not wide enough. Will give the D1 handle a go & see how it looks.
Old April 4th, 2014, 09:24 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks great Landy Andy!
I might "borrow" some of your ideas/designs when it comes time for me to do my dash. I don't want to spend a ton of money for a LHD one and I want to do an internal front cage and don't want to be cutting up said LHD dash. Plus the ability to run a nice cluster of gauges and some switches. Like the move of the vent control - that would give me room to run some tubing.
Old April 7th, 2014, 10:52 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Why is it, that when you try to do a simple swap it snowballs.... thought I'd fit the later wiper stalk with intermittent.... easy.... yes ?
No, they changed the mounting bracket that comes with the indicator switch too.... grrr.... need to get a new one of them now... might as well get the main light switch too, so they all look nice & new.... oh well
On a positive note, the new heater mounting bracket is 80% done and should move the heater up & back towards the bulkhead. Aim is to get the actuator that sticks out on the front left corner above the bend in the bottom of the dash. This should clean up the center section & make it less boxy..... hopefully
Also, measured up the room to move the wiper motor. There is enough space on the engine side of the bulkhead to go up ~25mm, so that should mean I only need a 15mm spacer ring for the new speakers.
Old April 12th, 2014, 04:54 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the new cut parts back.... tacked up & test fitted.... perfect fit
Think I'll add a grab handle each side... the current Defender door handles fits just nice below the side demist vent.
Vent flaps work too.... I get the option of half & full on the passenger side, that should work good for fresh air into the cabin as it's just above the air inlet for the HVAC unit.
Can now finalize the passenger side main panel & get that cut.
Old April 12th, 2014, 07:04 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
If you could reproduce this would be very sought after here on d90
Old April 12th, 2014, 07:40 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I was just going to ask if he could do a run of just the left side parts/panels the he posted pics of. Looks really good.
Old April 12th, 2014, 08:03 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I mean a lot of the customs dash projects look like something out of mad max. A clean metal kit that can accept an aftermarket blower with AC would be awesome. The stock dash and AC kits are so cost prohibitive that a reasonable slick aftermarket would be a great investment
Old April 12th, 2014, 08:06 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Totally agree - doesn't look all that far from stock.
Old April 12th, 2014, 08:56 PM
Landy_Andy's Avatar
Landy_Andy
Andy
That was my intention, to a non-LR owner it should look 'factory' or at least in keeping with the factory look
------ Follow up post added April 12th, 2014 05:57 PM ------
I may be pursuaded too, but not until I've finished mine first !
Old April 12th, 2014, 08:58 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I hope you fab an awesome center section; im thinking a clean metal puma style console with adequate ventilation.
Add an awesome glove box and boom! Let the orders rain lol
Old April 12th, 2014, 08:59 PM
cbfritz_03
Carmen
none
Agreed. It's really hard to make them look like they are supposed to be there. I've seen lots of them done and this by far is the best.
------ Follow up post added April 12th, 2014 08:00 PM ------
Agreed.. X3
Old April 13th, 2014, 01:16 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Passenger side already has a glove box in it, just working out final size before I get it cut. Centre section will get done once I get the HVAC unit bracket redrawn as a sheet metal part. It's almost done but needs to be mocked up first before I get it cut in metal. Current thinking is a pair of vents above the crash pad with a 6 way bank of Carling switches between them
Old April 14th, 2014, 12:55 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Yeah that's pretty sweet, thanks for sharing.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Old April 14th, 2014, 04:38 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks... have ordered one of the 11" long ones, should fit just nice above the glove box
Also decided I don't like the smaller grab handle on the end of the dash, so unless anyone can come up with a good reason to put one on.... it's gone !
Looking to mount my Maglite under the glove box, any other suggestions for stuff to go in the dash ?
Old April 16th, 2014, 12:44 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Here is the draft model for the passenger side, glove box opening measures approx 10" wide, 6" high & 6" deep, it slopes slightly down inside to stop things rolling out. Above will be a chunky grab handle for those interesting moments
And with the cover in place.
Question is.... is it too big ?
Would a 12V & USB socket be useful to the right of the glove box... what about a USB socket on the inside for phone charging ?
Old April 16th, 2014, 03:26 AM
göktu
göktuğ tuncer
1987
looks like perfect.
conversion, dash, lhd, rhd
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
WTB: RHD to LHD Parts texrover Wanted 3 May 10th, 2012 05:42 PM
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
LHD Dash parts for conversion Uncle Douglas Wanted 6 August 1st, 2008 02:17 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
