Custom dash for RHD to LHD conversion - Page 2 - Defender Source
Old December 18th, 2013, 01:22 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Go the control box today for the A/C unit... connected up and.... man does it move some air for such a small unit. Checked the Spal fan spec and at max output it's making over 300cfm, the flow from the defrost outlets is very good. I can see I'm going to be rather roasty toasty come next winter
Old December 19th, 2013, 12:13 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Andy, when you made the instrument panel pictured in the first photo, did you draw it up in CAD and have it cut with a water jet or similar?
I'm thinking about having a replacement panel made for my center-of-dash NATO convoy light switch. I want to mount an Auber digital EGT+boost gauge but I want to keep the truck looking as original and military as possible. I was thinking about a replacement panel that moved the light switch towards the edge, freeing up space for the Auber gauge. I haven't done much metal fabrication so I'm not sure where to start.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 19th, 2013, 11:56 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Hi Chris,
The dash in the first pic is the Lara Croft Tomb Raider truck... was built by LR Special Vehicles I believe.
I'm currently using Solidworks 3D cad for my projects but in the past have used Autocad. I get my parts water jet cut now as that's the only local option (still 2hrs away), in the past when I lived in the UK I had access to 3 laser cutting & 4 powder coaters within 30mins from home...
Old December 21st, 2013, 12:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
First dash part modelled, new demist mounting bracket that fit's into the dash top crash pad. It's very simple but working on these is getting me the hang of driving Solidworks, still need to finish off the holes for the demist vent but they've not arrived yet (can't see them being here until after the new year now).
So, onto the next piece....
If anyone sees a demist vent that's ~10" wide, ~1/2" wide at the opening has a 2" pipe connection and is vertically stubby (~3-4") shout out... the ones from T7 are the best I've found to date so will have to see how they perform once it's all hooked up.
Name:	dash top vent brkt.jpg
Old December 21st, 2013, 12:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Nice!
Old January 4th, 2014, 06:54 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got my first batch of cut parts back today... turned out OK
Can now continue with the rest of the dash design, think I'm going to model the bulkhead where the dash mounts first & then go from there. Will also make this one out of 16g steel as I can weld it here, or it might get bolted together.... not sure yet.
Old January 5th, 2014, 11:31 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Spent a few hours playing with Solidworks... and have the beginnings of the bulkhead model done. Back at it
Old January 5th, 2014, 11:35 AM
Archbronco
Josh
1983 Land Rover 110
This looks good. I will definitely be interested in the finished product.
Old January 5th, 2014, 11:44 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks... biggest problem I have is that we don't have a fab shop in town with a press brake, nearest is 2hrs drive away so will be making the dash in parts that I can bend on my box/pan bender. For the first will deff screw it together rather than weld...
However, does mean it's easy (and cheaper) to replicate.... umm Ikea dash in a box
Old January 5th, 2014, 12:32 PM
Archbronco
Josh
1983 Land Rover 110
The bronco guys have been making these for years for their projects. Plenty of good companies that can make your finished dash after you get everything sorted. Have you thought about different gauges etc...? Dakota Digital has some good products to update your dash and make plugin in that new engine much easier.
Old January 5th, 2014, 12:54 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I already have a full set of VDO instruments in the RHD instrument binnacle and am working on making it out of all RHD and existing parts too. I can see the supply of LHD parts drying up at some point (in the near future) and if someone wanted a LHD dash that's not OEM with A/C ... then... we have an opportunity
If that were the case I'd prob get it made out, for this one.... not worth it as the truck will spend 90% of the time in the woods & on the trails...
Old January 7th, 2014, 11:14 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Bit more progress... got some more of the bulkhead & top dash pad roughly modelled, need some external radius gauges to finish it off. Started on the drivers side sheet metal... will add a space envelope for the heater next & then do basic metal work for the passenger side.
Old January 10th, 2014, 02:07 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Added in the space envelope for the HVAC unit & the passenger side dash front panel. Need to do a test strip to check the front panel bends & then can look to get the drivers side cut.
Old January 11th, 2014, 11:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Slow & steady progress.... have added a radio DIN cut out, front vents & heater controls now. Struggling to make space for the original bulkhead vent openers.... any ideas on a good way to open & close them using existing parts ?
Old January 12th, 2014, 12:25 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks Jeff, unfortunately they won't fit either.... need to come up with a solution that moves the lever from being directly in front of the flap actuator arm. Was thinking I could repurpose the old duel heater control levers & cables. Need to see if they have enough movement & can latch the flaps closed enough.
Old January 12th, 2014, 12:40 PM
Archbronco
Josh
1983 Land Rover 110
That's a pretty keen idea JS. The levers are a definite weakness in the setup.
Old January 12th, 2014, 01:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The other option I've been toying with, is to secure the flaps closed as once the dash is all fitted you'll have to run the fan to get the fresh air into the cab. Will also keep the inside of the dash a bit more dust & dirt free.
I can put a fresh air duct/fan in from the wing top/side through the old heater duct hole in the bulkhead. Would only need another 3 speed switch & 2 more vent's in the lower dash area. With the fan off & the vent's closed it should keep the cold air out in winter but with the vents being in the bottom of the dash you wouldn't get cool air directly into your face but we have aircon for that now.
Old January 12th, 2014, 02:15 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Keep in mind the NAS 110's and the Puma dash trucks dont have scuttle vents.
-Jeff
Umm... but NAS 110's are already LHD & have A/C correct ? and by the time a Puma gets imported legally there will be plenty of LHD ones from Europe. Was thinking more towards the current RHD imports from the UK. That's why I didn't want to use any LHD dash parts in the conversion. Not directly looking to put a DIY dash kit together to sell but might as well leave that option open, am sure there would be a few takers on here to make a short production run worth while.
My only real concern then would be how much heat/cool the HVAC unit would put out for a 110 SW, I can see it being more than adequate in my truck cab but without fitting one into a 110 couldn't be sure.
Old January 12th, 2014, 02:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I did see this crazy set up that uses levers, but it eats alot of space.
-Jeff
They look like there extensions added onto the existing levers..... That dash appears to be just a front panel & top pod. Few too many breakers for my liking
Old January 12th, 2014, 04:27 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Just enough room on RHS of instrument binnacle to get the duel lever heater control in against the central cover section, so have added it. Will draw up a bowden cable mounting bracket for the vent flap end next & test it out. If that works OK the old RHD heater cables should be long enough to do both flaps. Will just need a used vent control to salvage a couple of cable grips & screws. Should make a nice 'OEM' looking install if it works
conversion, dash, lhd, rhd
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
WTB: RHD to LHD Parts texrover Wanted 3 May 10th, 2012 05:42 PM
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
LHD Dash parts for conversion Uncle Douglas Wanted 6 August 1st, 2008 02:17 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
