Custom built rear bumper, chassis repair and rollcage installation - Defender Source
Old July 5th, 2015, 11:19 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile Custom built rear bumper, chassis repair and rollcage installation
I can finally share the latest upgrades to my 1997 D90, the old Cube II
It all started when - a couple of years ago - I found out the rear crossmember was rotten beyond repair; not a big surprise, being a well known "mud trap" due to poorly thought design, and made of thin foil too
I immediately binned the idea to replace it with a standard spare part, simply not worth the money and effort required; I looked instead at a better solution (read: custom-designed and fabricated), and I liked the idea of some heavy duty, bolt-on rear bumper, Jeep style! Yes Jeep...I said that. I saw a picture of a GenRight HD bumper on the web and decided it was simple and practical.
Pros:
1)stock looking (stealth mode: ON)
1)easy to remove/repaint/repair if needed
2)better designed and made, a simple open "]" profile, built stoutly out of, say, 6mm plate
While there, it happened that a few months ago I was finally able to afford a proper rollcage, beautifully built by Protection & Performance; sooo, to kill two birds with a stone, all I needed was the right person to do the job, my way.
Meet Edoardo, the brain behind Payustech Performance.
With a straightforward approach and armed with a 3D scanner, the rear section of the chassis was checked and scanned, and a HUGE jig was built to ensure precise fitment of the new repair sections and crossmember.
All the rotten metal was chopped, the whole structure was designed in 3D, checked and approved, then and laser cut, bent and assembled.
The Protection & Performance rollcage came already welded and painted, but the supplied mounts need to be welded to the chassis.
Edoardo didn't think twice and incorporated the rear mounts into the design, along with gussets and bracing to ensure bomb-proof rigidity.
Beads of weld were laid down on the chassis and the puzzle went together.
The result is a stock looking chassis, until you get closer and start noticing the big bolts which hold the new bumper in place...
Here's a link to a bunch of photos I shared on FB:
https://www.facebook...=1&l=d6a1098f12
An cool 3D video showing the whole puzzle:
https://www.facebook...284162753972044
Also a couple of pics of the Cube now
ID:	124322   Click image for larger version
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old July 5th, 2015, 12:25 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Facebook links aren't working for me.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old July 5th, 2015, 01:58 PM
Not working for me either. I'll just go to FB.
Old July 7th, 2015, 07:06 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Weird :-/
Silly links!
I'll check tonight or tomorrow...
Michele
D90 VNTdi
[O]===[O]
Old July 7th, 2015, 08:22 AM
Originally Posted by Cube II View Post
Weird :-/ Silly links! I'll check tonight or tomorrow...
Just you tube them!
Old July 7th, 2015, 08:58 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
While it's not the topic of this thread I really like that front bumper. I've always wondered why there haven't been more simple and tidy winch set-ups like you've got. Is it custom?
My other car's a Land Rover
Old July 7th, 2015, 09:01 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You can get a Rockware that's pretty similar and has great lines IMO, I know Chris has one and I believe Charles does too
Old July 7th, 2015, 09:12 AM
Looks great, Michele!
His front bumper is totally custom. It looks similar to a Rockware, but there's a lot of custom touches...the most obvious is the 8274 winch mount.
It's Michele's style...a lot of the differences are in the details
Here's the facebook link. As you can see although it might look like a rear Rockware bumper on the outside, on the inside, it's nothing like it...
https://www.facebook.com/Whitedog.Comics
Old July 8th, 2015, 05:30 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Yes, fully custom, made on my own design, but it's really simple...oh, 100% stainless steel
Just like the rocksliders, it will never rust.
Michele
D90 VNTdi
[O]===[O]
Old July 8th, 2015, 05:43 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Smile
(cut)
(cut)on the inside, it's nothing like it...
Thanks for the kind words!!!
I always try to keep things simple, stock looking and therefore matching the boxed shape of the D we all love...no tubular things for me. Well, rollcage apart
Maybe it's easier to attach pics the old way...and the video too, so you can see how it's built
If you guys are on FB, feel free to befriend me
ID:	124555   Click image for larger version
ID:	124557   Click image for larger version
ID:	124559   Click image for larger version
ID:	124561   Click image for larger version
Michele
D90 VNTdi
[O]===[O]
Old July 8th, 2015, 06:06 AM
Cube II's Avatar
Cube II
Michele
1997 D90
A couple more.
You can see how the bumper ends are "closed" and the two holes are for the bolt-on corner guards (coming soon).
These will be "minimal" and low profile, as usual
ID:	124563   Click image for larger version
Michele
D90 VNTdi
[O]===[O]
Old July 8th, 2015, 06:23 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Video
As suggested, I uploaded it on Youtube.
Since I can't get a clue of how to make the cool preview work,
you only get a simple link to click on!
https://youtu.be/GMxY_v2DQVw
Michele
D90 VNTdi
[O]===[O]
Old July 8th, 2015, 08:26 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Outstanding!
Great design. Obviously you have skills
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old July 8th, 2015, 11:14 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Wow! Really nice. Now that is how LR should have done it from the factory. Instead of the mud/crud catch and hold design they use.
Old July 8th, 2015, 03:15 PM
Cube II's Avatar
Cube II
Michele
1997 D90
I have ideas
3D engineering courtesy of the mate at Payustech
Originally Posted by Reese_D90 View Post
Outstanding!
Michele
D90 VNTdi
[O]===[O]
Old July 27th, 2015, 07:08 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
Looks fanhonkin'tastic.
I just bought one of those tailgates, but they didn't send me the pins. I may have to buy them separate if I can't figure a way to make it swing. I may follow suit.
Old July 28th, 2015, 03:27 PM
Cube II's Avatar
Cube II
Michele
1997 D90
LOL, thanks!
Yes the tailgate may be "modified" to swing,
you need a couple of SW rear door hinges, and an handle.
Then either cut a window for the handle, or use the antiluce catch.
Michele
D90 VNTdi
[O]===[O]
bumper, cage, installation
Expedition built 110s, custom 135s Talleyrand Misc. Chit-Chat 6 February 19th, 2014 05:13 AM
Rockware rear bumper & tire carrier Installation Tips nycjdp Defender Technical Discussions 2 May 24th, 2009 01:33 AM
What is this Bellargio, 1959 TDI5 custom built SafariHP The Flea Market 5 July 23rd, 2008 01:06 PM
Custom Built Defender :) playing in the mud Frankie Carbone Misc. Chit-Chat 1 April 11th, 2008 12:35 PM
rollcage rollcage rollcage javablack Wanted 0 October 9th, 2005 05:06 PM
