Crossmember-Tub screws - Defender Source
Old August 18th, 2008, 04:32 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Anyone replace these with stainless?
Can you let me know what you used and should I need to worry about anything before starting to replace these?
Tom
Old August 18th, 2008, 07:39 PM
Yes, I did mine several years ago. The book answer is to use nylon washers anywhere where you risk stainless to aluminum contact, I'll admit to not doing that. Of the 10 locations, only outside 4 have that potential problem as I see it though. The rest thread into steel plates riveted to the tub. I do use anti-seize on my stainless.
Old August 19th, 2008, 12:06 AM
Use nylon washers and slip rubber sheeting between the tub and the tabs.
Old August 19th, 2008, 07:27 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
thanks guys, great advice!!
Old August 31st, 2008, 05:35 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I got them changed this weekend..thanks guys.
Old September 1st, 2008, 09:53 PM
Firefighter2904's Avatar
Firefighter2904
jason
97 d-90
any chance that you have the sizes of the bolts? I am looking to do the same project this week and have been unable to find a listing on the size of the bolts.
Thanx,
Jason
Old September 1st, 2008, 10:13 PM
They are M8x25. The center 6 thread into captive nuts riveted to the tub. The outside 4 require washers and nuts. Nyloc nuts are best here. Might be a good place for the much-ballyhooed nylon washers as well.
Old September 2nd, 2008, 08:00 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Jim is correct, use PB Blaster on everything prior and you will have no problems.
It was very straight forward for me and I did use Nyloc nuts on the outside pairs. Again this is just one more thing out of the way which is protected from the rust monster.
rollcage,ARB's, 4.10's GBR, badger, D90 tub Shane@EVS For Sale - Parts 20 March 20th, 2006 06:41 PM
SW driver/passengerside doors wanted as well as centor console tub jchan88 Wanted 4 August 7th, 2005 09:04 PM
Galvanised tub capping jabber Defender Technical Discussions 9 March 3rd, 2005 09:35 PM
tub width on a '94 D90 is tapered "natural"? paulb Defender Technical Discussions 3 August 18th, 2004 07:07 PM
