Cross Member - Page 3 - Defender Source
Old November 14th, 2012, 01:13 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
That came out good!
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old November 14th, 2012, 01:28 PM
Spray the inside with waxoyl now. especially get the seam where the two pieces overlap.
Old November 14th, 2012, 01:33 PM
Lrd90
Anthony
95 Defender 90 (SOLD)
I did use Waxoyl on all bolts and Por 15 on frame.
Old November 14th, 2012, 02:01 PM
Put waxoyl on the frame too. Mainly the inside of the crossmember where the tires kick up stone and mud and where the two peices of metal along the bottom edge of the crossmember are.
Old November 14th, 2012, 02:22 PM
Lrd90
Anthony
waxoyl only on bolts. using Por15 paint on entire frame.
Old November 30th, 2012, 07:48 PM
landrovermanuk's Avatar
landrovermanuk
John Lindsay
1986 Land Rover 90, 3.9Efi
A chap over here in the UK built his own rear cross member from some think like 6mm plate, welded in crush tubes and welded on caps to the end of his chassis and then bolted the cross member on. I cant remember if he galvanized it or not but he could unbolt it for repairs and painting etc if required.... Just a little idea to throw into the mix...
Land Rover 90, 3.9Efi Auto, Soft Top, NAS spec, Tangiers Orange.
Land Rover owners like it rough and dirty...
Old November 30th, 2012, 08:26 PM
Michael110's Avatar
Michael110
Michael Dickin
1986 110 Tithonus - Now Sadly Sold
New galv won't take paint well at all, due to the shiny surface, the paint will peal off in sheets. In the UK, where replacing the chassis with a new galv one has been common for a a couple of decades now most folks want to hide the fact that the chassis is galv as it makes the land rover an obvious target for thieves. To get paint to stick to new glav first it need to be dulled with an acid solution, then washed copiously (the otherwise the acid keeps eating the galv, then etch primed and finally painted with a paint chemically compatible to the primer. The other way is to leave the galv exposed for a year or so and let the weather do its stuff and the oxide layer form on the zinc, which will take paint much better.
Defender R380 Gear Box Cross Member - ANR6386 pabrit For Sale - Parts 5 May 16th, 2012 02:30 PM
Rear cross member replacement problem slowpoke496 Defender Technical Discussions 26 May 7th, 2012 09:21 AM
Complete SG 3-Link and HD Cross Member 97D90 For Sale - Parts 22 January 22nd, 2009 09:34 PM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
