Cosmetics on my 130CC - Page 4 - Defender Source
Old September 13th, 2014, 05:05 PM
WBSurfer's Avatar
WBSurfer
1995 RRC
That looks awesome!
I wish I had skills like that. Very cool console set up!
Nice Work!
Old September 13th, 2014, 06:33 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thanks Chris.
But I don't really have the skills.
I just take the time of doing it.
And it takes a lot of time to get such a wooden model ready!
Today I'm happy to have it done to this alignment.
But unfortunately the transfer lever doesn't has enough space to shift into low position!
So this design has to be changed another time.
It's just a way cool-o-mat job for the older of us. Needs pation and the look for making things from flat material.
The coating with leather is another part to be remembered.
It will take some more hours to get me satisfied with these parts for sure.
But I never surrender.
Old September 14th, 2014, 01:44 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The wooden model is ready.
Time to think about a layout for the aluminum sheets.
Old September 16th, 2014, 03:14 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Joined the junk yard today.
Got 3kg of aluminum sheets for 3€.
So the first cover is ready.
Big surprise when I pulled off the protecting film: one side is coulered white!
Old September 16th, 2014, 03:25 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by Arlo View Post
Joined the junk yard today. Got 3kg of aluminum sheets for 3€. So the first cover is ready. Big surprise when I pulled off the protecting film: one side is coulered white!
Whoops! Lol hope you were planning on paint or leather wrap
Old September 16th, 2014, 03:55 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I'm thinking about leather.
Old August 14th, 2015, 05:08 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I'm running the car since last year without reversing light.
This has to changed right now.
And a correct blocking the starter issue has to be installed.
The round connector of the ZF box works fine!
Just connect the both mostly green lines to the existing plug and the reverse lamp gets illuminated if in "R"!
The remaining both black lines should be connected to the starter relais's cut off 85 or 86 to interrupt the possibility while in "R", "D", "1", "2" or "3".
To get some light inside the roller deck just add a switched line to it.
No progress in the leather maintenance.
I'm sorry about that.
Old August 20th, 2015, 04:15 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Leather dressed sheets of aluminum!
Old August 20th, 2015, 04:37 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Did you put foam under the leather?
Thinking of doing some panels like this on my series when I get there. Putting 1/4-1-2" foam down should give it a smooth tight finish.
Old August 20th, 2015, 04:39 PM
Nice teddy in the dash.
Old August 20th, 2015, 05:01 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
No foam fitted.
------ Follow up post added August 20th, 2015 03:04 PM ------
Do you like horny teddies?
Old August 25th, 2015, 02:36 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Got the huge opening closed today.
And it's easy to pull it out!
Old August 25th, 2015, 03:55 PM
87 D110 (Ruby)
you need more buttons and gauges in that panel mate.
Old August 25th, 2015, 04:20 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
That's for sure!
Give me an other year and we will see.
1997 Land Rover Defender 130CC Arlo Defender & Series Truck Registry 0 July 18th, 2014 12:56 AM
