Cooling - Defender Source
Old January 7th, 2010, 05:19 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Cooling
Jegs 52000-19 aluminum universal radiator for chevy 28"x16.5" $172.00 shipped
Bend up some new mounts for it and weld= 1 hour and scrap metal in shop
two puller fans from late model Honda
temp control wiring kit from auto parts store. wire though toggle so you can turn it off for deep water
small clear overflow tank from the junk yard.
Cheap, easy, COOL
And hay
And I love you too
Old January 7th, 2010, 06:02 PM
Post a pic...
Old January 7th, 2010, 06:37 PM
huck1974's Avatar
huck1974
shane cates
94 d90
try to soon. I'm bad at pics. Check out the jegs site and that part number
And hay
And I love you too
Old January 8th, 2010, 06:36 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Need to add that you need a different hose for the radiator output. I can post the number (Gates) when I'm at the shop next. The outlet of the new radiator is bigger.
You have to weld the homemade lower mounts on top of the factory mounts. If you bolt them on, the radiator cap will not clear the hood.
And hay
And I love you too
Old January 16th, 2010, 08:51 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Switched to a home made shroud with a single 2600cfm puller. The fan only comes on for about a minute at a time while leaving it at idle. I'm pleased
And hay
And I love you too
Defender cooling fans with clutches pendy For Sale - Parts 2 January 15th, 2006 11:47 PM
Radiator Cooling Trouble mgrgpg Defender Technical Discussions 29 March 14th, 2005 05:43 PM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
cooling system rover4x4 Defender Technical Discussions 1 October 21st, 2004 02:02 PM
What cooling mods have you done? read Misc. Chit-Chat 6 October 24th, 2003 01:34 PM
