Closing in on a winch, final thoughts? - Page 4 - Defender Source
Old December 15th, 2014, 02:14 AM
wow! that looks fantastic! lovely job.
Old December 15th, 2014, 02:24 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Looks really good!
Old December 15th, 2014, 07:39 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by rankar View Post
Thanks everyone for all the suggestions, tips, etc. My project is complete.
Jeff suggested using a factor 55 winch lock bolt for security. So I got two of them.
The only pain was that warn has a large slot for the square nuts. This didn't work for the 3/8-16 factor 55 bolt.
So I used some steel bar stock that I had lying around, cut and ground it down for a perfect fit, then drilled and tapped it. I wanted all four nuts to match, so I made four of them.
And finally, everything was as close to the body as possible, with only a10mm clearance. Just a small trim job to the stock grille and it all fell into place...
Very nice.
Old December 15th, 2014, 07:54 AM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
Really like the set-up! Excellent work!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old December 16th, 2014, 04:18 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Thanks again guys for all the comments. This would not have been possible without all your help.
I used superwinch branded quick connectors (Anderson power pole type, genderless) for the winch. I brought the connectors right to the tray and I made the below from another set of connectors. Now I can jump cars quickly (or get one myself) with the winch power line. The kit (pair of connectors, lugs, and covers) is only $35.00
Or just connect both ends of the jumper cable connectors for traditional use.
ID:	108783   Click image for larger version
Old December 16th, 2014, 04:31 PM
Originally Posted by Ohlins View Post
Great write up which will no doubt help other Inmates....thanks for posting.
What's with all the prison references you keep making?
Old December 17th, 2014, 02:33 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Stick..wrong end of.....
Humour and quite the contrary...Inmate as in Madhouse Inmate.
In forums such as these we discuss the size of nuts and bolts.....we take photos of our LR's and post them...we give our LR's names and buy them presents.....I'd say if any of us showed our wives half of the threads they'd just look at us blankly,shake their heads and walk off mumbling something incoherent. That's a certificate in itself.
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old December 17th, 2014, 09:06 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
When I had a Anderson set up on my disco- now on my Kubota-, I sealed the back sides of the connectors with rtv to keep mud/muck/sand and forest floor slime out of the connector, and coated the contacts with dielectric grease. Disconnecting and reconnecting would usually clean away corrosion, but for me, I thought it was a good peace of mind to cut down corrosion/resistance.
Email is
Same place, new dogs.
Old December 17th, 2014, 09:21 AM
rankar's Avatar
rankar
Thanks Trevor, I'm going to do that
ht, winch
Final thoughts on my other threads!! RickM Defender Technical Discussions 0 May 4th, 2010 11:02 AM
Hood not closing.... Rover- Girl Defender Technical Discussions 17 June 7th, 2009 04:53 PM
Final Pieces for the wedding bstraw Wanted 28 May 17th, 2009 06:00 AM
Safety Device NAS D90 roof racks return (part 5, final chapter) ECR Misc. Chit-Chat 23 March 31st, 2009 03:42 PM
Closing a thread + tech articles paulb Support & Suggestions 4 November 2nd, 2004 01:36 PM
