Closing in on a winch, final thoughts? - Page 3 - Defender Source
Old July 25th, 2014, 03:53 PM
LR Max
Thomason, Max
1973 Series 3 109
Originally Posted by cgalpin View Post
Although I agree, I'd point out that I that was out general attitude we'd probably all drive jeeps
You have a point. That said, having messed around with quirky and non-mainstream things has shortened my attention span over the years. Going with something mainstream and making life simple is nice.
Also if you really wanted to do the jeep thing, you'd be buying a Smittybilt.
Old December 2nd, 2014, 02:17 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Ok I've changed direction a lot on this but finally getting it done. I'm almost finished with rebuilding an 8274.the bumper is done though. I picked up a warn center section (it's very hefty and just clears the outside front chassis members), welded a box piece on each ended, tabs for mounting , then welded the bumper nuts to the underside. Total weight is about 80 pounds. Perfect.
Since this was heftier than anything I've ever welded, I needed some help from my friends at a local shop, then I finished everything else.
ID:	107929   Click image for larger version
ID:	107931   Click image for larger version
Old December 2nd, 2014, 07:55 PM
Contractor's Avatar
Contractor
Will
1969 IIA
That looks really good, nice job.
Old December 2nd, 2014, 09:12 PM
Looking good!
Old December 2nd, 2014, 10:33 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by rankar View Post
Ok I've changed direction a lot on this but finally getting it done. I'm almost finished with rebuilding an 8274.the bumper is done though. I picked up a warn center section (it's very hefty and just clears the outside front chassis members), welded a box piece on each ended, tabs for mounting , then welded the bumper nuts to the underside. Total weight is about 80 pounds. Perfect. Since this was heftier than anything I've ever welded, I needed some help from my friends at a local shop, then I finished everything else.
That's a great setup! Great job on that
Old December 3rd, 2014, 05:58 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I like it. It's a simple design.
Semper Fi!
Old December 3rd, 2014, 07:25 AM
rankar's Avatar
rankar
thanks guys. i couldn't believe it when i found the perfect center section:
http://www.amazon.com/gp/product/B00...productDetails
such an awesome deal i bought two. not sure why, but if someone wants that center section let me know.
and since I'm an amazon prime member, the two-day shipping was free. total cost was $211 for that very beefy center section. it's originally for dodge trucks, but one could do this without the attached ends and slip it onto the chassis members directly like this (from gigglepin:
Old December 3rd, 2014, 07:47 AM
I really like how GP tapered the sides of their 8274 winch tray. It gives it a more streamlined look for sure.
Old December 13th, 2014, 12:26 PM
rankar's Avatar
rankar
Ed's 8274 thread got me off my duff and get going on mine. Here are a few pics.
Old December 13th, 2014, 12:27 PM
rankar's Avatar
rankar
Here it is fresh back from powder coating. New lower unit rebuild kit and starting to reassemble.
Old December 13th, 2014, 12:30 PM
rankar's Avatar
rankar
Installed motor. I used a gigglepin motor gasket so I wouldn't have to use rtv to seal it everytime I need to pull the motor.
Old December 13th, 2014, 12:32 PM
rankar's Avatar
rankar
I attached a new ground lug to the let casing. I used a stainless lag bolt, cut off the top, and used two nuts to secure it. Stainless is a horrible conductor, so I'll test this out before finalizing it.
Old December 13th, 2014, 12:35 PM
rankar's Avatar
rankar
I used the gigglepin solenoid and cable boots on welding wire. I took advantage of the 5 pin connector to have it switch the ground as well. If for some reason I had a ground fault, I spkiced in a quick connector to bypass the remote ground switch and plug directly into the solenoid.
ID:	108582   Click image for larger version
Old December 13th, 2014, 12:40 PM
rankar's Avatar
rankar
Make sure not a single strand of wire has a chance at exposure. So I used shrink tubing on all the contact points.
It's always easier and better to just get a new socket. Warn makes it easy by labeling the ground, attaching ring terminals for battery connections, and the other connections are grouped along the DPDT switch.
I got a new metal, powder coated housing cover. This made it look even better. Attach the final top decal and its ready for its install.
ID:	108588   Click image for larger version
ID:	108591   Click image for larger version
Old December 13th, 2014, 03:54 PM
no worse than the yoke. youll be fine. my stainless ground stud conducts fine for a stud
Old December 14th, 2014, 04:02 PM
rankar's Avatar
rankar
Ok cool, thanks Ed
Old December 14th, 2014, 04:12 PM
rankar's Avatar
rankar
Thanks everyone for all the suggestions, tips, etc. My project is complete.
Jeff suggested using a factor 55 winch lock bolt for security. So I got two of them.
The only pain was that warn has a large slot for the square nuts. This didn't work for the 3/8-16 factor 55 bolt.
So I used some steel bar stock that I had lying around, cut and ground it down for a perfect fit, then drilled and tapped it. I wanted all four nuts to match, so I made four of them.
And finally, everything was as close to the body as possible, with only a10mm clearance. Just a small trim job to the stock grille and it all fell into place...
ID:	108676   Click image for larger version
ID:	108678   Click image for larger version
Old December 14th, 2014, 04:18 PM
Nice work! Did you put anti-seize on all of the bolts?
Old December 14th, 2014, 04:22 PM
rankar's Avatar
rankar
Thanks Jimmy. And yes, definitely on the anti seize. I've busted enough knuckles for a weekend tinkerer.
One of our cats decided to make a cameo, thought you'd like that.
Old December 15th, 2014, 12:15 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Great write up which will no doubt help other Inmates....thanks for posting.
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
ht, winch
Final thoughts on my other threads!! RickM Defender Technical Discussions 0 May 4th, 2010 11:02 AM
Hood not closing.... Rover- Girl Defender Technical Discussions 17 June 7th, 2009 04:53 PM
Final Pieces for the wedding bstraw Wanted 28 May 17th, 2009 06:00 AM
Safety Device NAS D90 roof racks return (part 5, final chapter) ECR Misc. Chit-Chat 23 March 31st, 2009 03:42 PM
Closing a thread + tech articles paulb Support & Suggestions 4 November 2nd, 2004 01:36 PM
