Check Engine Light - Defender Source
Old December 11th, 2007, 02:01 PM
defender1844
Amit Likhyani
Check Engine Light
It says the wiring harness is bad. The truck runs fine. Any advice on how to diagnose and fix this problem?
Old December 11th, 2007, 02:05 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
if it runs fine then its not broke, don't fix it
3rd low and BOOT IT
Old December 11th, 2007, 02:34 PM
defender1844
Amit Likhyani
I can't get a sticker with a check engine light in Texas.
Old December 11th, 2007, 02:43 PM
Kill a chicken and take out the bulb?
Old December 11th, 2007, 02:44 PM
defender1844
Amit Likhyani
I think big brother's emissions checking machine interfaces with the ECU and knows that the check engine light is on. Come on guys, someone must have had this problem.
Old December 11th, 2007, 03:46 PM
Is it a 1994/95 or a 1997?
Old December 11th, 2007, 03:54 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
94's don't need to be hooked up, not sure obout 95/97
3rd low and BOOT IT
Old December 11th, 2007, 04:28 PM
Pre 1996, no OBD II can't hook them up to the machine.
Old December 11th, 2007, 04:32 PM
defender1844
Amit Likhyani
It's a 97. Should have clarified that.
Old December 11th, 2007, 05:23 PM
What is the exact code? It is O2 sensor shorted?
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
