Changing shocks and coils - Defender Source
Old April 10th, 2014, 02:49 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
guys, i was reading the nas d90 shop manual on how to replace the shocks and springs. i've never replaced shocks and springs on a car (probably from some high school trauma when i watched in amazement as my pal was attempting to do the same thing on his old toyota supra-i think it was- and the spring came out of its housing, shot down into the driveway and put a massive dent in it).
is it really that easy to change on a 90, like it says in the manual? don't need a compression tool or anything? any other thoughts before i tackle this over the next few weeks (i'll probably replace the shock towers too). thanks all.
Old April 10th, 2014, 03:10 PM
Easy peasy. No spring compressor required.
Old April 10th, 2014, 03:12 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Did rears a few days ago -- took about an hour.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old April 10th, 2014, 03:13 PM
rankar's Avatar
rankar
hey dave thanks. i'll report back in a few weeks (it'll take a minimum of two weeks for me to get over the image of the killer coil in high school).
Old April 10th, 2014, 03:32 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I made a video on how to change shocks and springs on a Disco 2, which would mostly carry over to the D90 with the exception of the mounting style on the shocks.
Old April 10th, 2014, 03:37 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Originally Posted by rankar View Post
is it really that easy to change on a 90.
Yep. You can probably do them all in a few hours by yourself if the nuts/bolts are in good shape.
Old April 10th, 2014, 03:47 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I would make sure I had on hand an extra set of tower retainer rings on hand. You will most likely break a bolt when taking it off. Also use anti-seize on the bolts when you reassemble for future use.
Old April 10th, 2014, 03:51 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Heard that.... just had to buy one of those rings when changing shocks on my D1
Old April 10th, 2014, 04:18 PM
The bottom of the front shocks is the biggest problem. Unless you live in a dry, non winter area they will be impossible to undo. You then need to break them or cut them off.
Old April 11th, 2014, 07:34 AM
rankar's Avatar
rankar
Thanks guys for all the helpful info. And, just watched the video. Thanks for forwarding the link Zack, that was very helpful.
If I have my assistant with me (my son) then I'll shoot a vid. Could be several hours of bolt banging though.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Old August 16th, 2014, 10:33 PM
rankar's Avatar
rankar
So check this out...
I finally got to this small project after some other odds and ends. And when I took this pic, all was ok. Then I started on the retainer rings... I sheared almost every bolt.
I know Jason, you said to have some spares and I didn't get them. So now I'll order four rings and some new shock towers while I'm at it.
What other parts would you guys recommend while I'm in there?
Old August 16th, 2014, 11:18 PM
rankar's Avatar
rankar
Thanks Jeff. Back to the coils in a couple of days or so...
Old August 21st, 2014, 08:41 AM
rankar's Avatar
rankar
Yup thanks Jeff. Got the parts the other day, and the big jaw locking vise grip just because it's a cool tool (saw that on another thread on shocks).
For some reason, the usual suspects didn't have galvanized shock towers in stock so I just got the standard height terrafirma heavy duty open towers.
Old August 24th, 2014, 06:41 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Always best to break the fasteners loose on the tower retaining rings before you jack the truck up.
The D2 style rings are preffered, they are rubberized, use nylock bolts, little cones built in, better design overall.
Old August 26th, 2014, 11:41 AM
rankar's Avatar
rankar
Finally. All done. Here's a shot of the front (it's raised just a bit because of the uneven pavement). Thanks guys for all the advice.
Old August 26th, 2014, 11:46 AM
rankar's Avatar
rankar
And an action shot my wife took as I was doing the last one
coil
Genuine Front and Rear Springs Coils from NAS 90 SMac For Sale - Parts 7 October 26th, 2013 01:24 PM
reliability of MSD multi-spark ignition and coils cdb Defender Technical Discussions 5 April 12th, 2011 08:29 AM
Is it normal for Coils to get very hot? btate Defender Technical Discussions 13 August 26th, 2007 11:03 PM
re: What coils do I have?? cneal Defender Technical Discussions 3 November 16th, 2006 01:58 PM
burning up coils tmore Defender Technical Discussions 2 July 23rd, 2005 07:43 PM
