Carling Contura II switches - Page 2 - Defender Source
Old March 9th, 2016, 11:06 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
SPST will only open/close one circuit
DPST will open/close two circuits with the same throw direction, not to be confused with...
SPDT will open one circuit while closing another circuit in a single throw
Old March 9th, 2016, 11:09 PM
RBBailey
RBBailey
1965 IIa
Oh, of course. Single Throw! Knew I would be stupid! Thanks.
So what type of application would I want DPST for? -- Two sets of lights on one switch?
Project:
1965 IIa SWB
Old March 9th, 2016, 11:31 PM
Originally Posted by RBBailey View Post
Looking to replace all Rover switches on the dash, except for rear defrost and hazard as those must stay in position till I figure a way to naturally blank out that space.
I *believe* yours is LHD...I do have an option for that lower dash switch plate to convert over to Carlings actually:
ID:	144678   Click image for larger version
Old March 9th, 2016, 11:37 PM
rankar's Avatar
rankar
two sets of lights controlling two separate relays, for sure.
anything where you'd want to have two circuits open and closed both at the same time. i was thinking of wiring a flood option, like what pilots have, but it would flood (turn on) all the interior lights and all external work lights.
all kinds of cool stuff. and yet another reason to tear into our rovers...
Old March 10th, 2016, 07:29 PM
RBBailey
RBBailey
1965 IIa
I'm thinking I want the Contura XIV style -- do you know if the tight spot there might interfere with the switch in either off or on position?
Project:
1965 IIa SWB
Old March 10th, 2016, 08:03 PM
Do you know offhand what the callout is for the XIV mounting hole? Or the outside dimensions of the switch itself? Essentially if it's the same as the Contura II or III it'll be fine.
Old March 10th, 2016, 08:20 PM
RBBailey
RBBailey
1965 IIa
I think the switch itself is the same. Don't know about the face.
Anyone know of a good alternative switch for the stupid looking rear wiper switch that is mounted on the NAS 110 type dash? I almost think a horizontal Contura switch with multiple positions would look good there.
Project:
1965 IIa SWB
Old March 10th, 2016, 08:41 PM
I like the way these guys will customize the switch face!
https://otrattw.net/CONTURA-V-ZOMBIE...PZCZL-5ZL.html
Old March 10th, 2016, 08:44 PM
You know that Carling has a Rear Wash/Wipe Switch (below)? It's essentially OFF-ON-MOM, which also happens to be my starter button .
Old August 16th, 2016, 08:06 PM
RBBailey
RBBailey
1965 IIa
^ That there is what I've decided to go with for style and color, but this web site doesn't seem to have what I want, or not in enough different versions. i.e., white with the right icons. I keep going there thinking I must be missing their full selection, but...
So I'm wondering a couple of things:
First, are there any other web sites out there that you have had success ordering from?
Second, have any of you bought blank rockers, then used the stickers? Seems like it could be good or bad.
Project:
1965 IIa SWB
Old August 16th, 2016, 08:16 PM
Not quite sure what icons you need but call them up. They etch switches to your needs. On some bulb color can vary to
Old August 16th, 2016, 08:54 PM
RBBailey
RBBailey
1965 IIa
That may work, I'll email them with a list of the rockers I'm looking for.
OK, now the hard part... figuring out how to match to the switch type I need!
Project:
1965 IIa SWB
Old August 16th, 2016, 10:07 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Have you tried dirty parts?
Old August 16th, 2016, 10:12 PM
Another supplier: Professional Designer of Rocker Switches and Switch Panels -Air On Board
Old September 18th, 2017, 02:14 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
bumping an old thread...
Does anyone know if I can use a carling on-off switch for the rear defrost?
Or what would be the correct switch to use?
Thanks!
Old September 18th, 2017, 05:01 AM
Originally Posted by lithium1330 View Post
bumping an old thread... Does anyone know if I can use a carling on-off switch for the rear defrost? Or what would be the correct switch to use? Thanks!
HRW has a relay or should have a relay on it. So yeah you can.
switch
MUD Pod w/ 6 gang Carling switch mount jefhuf For Sale - Parts 8 August 23rd, 2012 12:02 PM
Mud UK Carling switches, holders, blanks and more dave_lucas For Sale - Parts 13 March 26th, 2010 05:55 PM
Will 3 Carling switches fit here? cabell Defender Technical Discussions 9 July 15th, 2009 10:51 AM
Contura Switch 3 way and 2 way Rugbier Defender Technical Discussions 21 January 26th, 2009 11:45 PM
Carling Switches mgrgpg Defender Technical Discussions 5 September 12th, 2007 06:06 PM
