Bumperette Spacer Brackets - Defender Source
Old May 17th, 2011, 12:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Here is a very small project. I bought Terrafirma Bumperettes but the Mantec spare tire carrier interferes with the Bumperette mount so I am making spacer brackets to allow the right hand Bumperette to be mounted on top of the spare carrier mount using the same bolt. More pictures of the install to come once the brackets have been cut. First picture shows the bracket templates and 2nd show how the Bumperette would attach on top of brackets and spare tire mount.
ID:	38788   Click image for larger version
Old May 17th, 2011, 04:43 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
looks like useful information! has anyone successfully fit a set of these with a NAS tire carrier?
Old May 17th, 2011, 04:45 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Isn't the NAS tire carrier a Mantec? My truck is NAS and I always though the tire carrier was Mantec but I could be wrong. How can you tell? Is it marked?
Old May 17th, 2011, 09:57 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
No, yours is the Mantec...the NAS carrier mounts are on the crossmember at the PS corner and at the top of the tub on the PS. The NAS carrier makes mounting any kind of corner guard very difficult!
ac, bracket, bumper, rack
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
rear bench brackets jts Defender Technical Discussions 1 November 20th, 2005 09:42 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
