Bulkhead Heater Blower Modification - Defender Source
Old December 21st, 2015, 11:01 AM
UserName's Avatar
UserName
Andy
Janey
Posting this for anyone researching / considering the bulkhead modification to get more airflow from your heater blower: it really worked well for me. Prior to expanding the size of the hole in the bulkhead I could barely tell when the heat or defrost was running now I get blasted with heat. Not that it has been very cold, but I was driving this weekend when it was 25 degrees out and I did something I have never done in any Rover during winter I turned the fan speed and heat down, it was too hot.
The passenger compartment in my truck warms up faster than my wifes brand new Toyota. I suppose this might not hold true for passengers in the back since the Toyota also blows heat to the second and third rows, but plenty of CFMs and heat for those in the front row of the Rover.
This Ad Space For Sale!
Its the only space left on this site not already running a slow loading pop-up commercial.
Comes with free cookie downloader and user tracking virus. (superior to the ones Vertical Scope downloaded onto your computer when you logged in)
Old December 21st, 2015, 11:08 AM
yep. big difference for me. what also helps is to upgrade the wiring going to the blower to 14AWG. getting less ohms resistance on old wiring from the heater switch (ground) and the pos lead from fuse panel to blower will help boost an otherwise old and anemic blower motor.
Oh, and check for leaks. Good suspect places for heater air leaks are the mating between bulkhead and blower (now that you've opened it, did you come up with a new gasket?), and demister ducts grommets (big ones that seal the duct where it enters the heater planum chamber).
Mark Kellgren
KM4BOR
Old December 21st, 2015, 12:06 PM
Mark's thread on this miracle of heat!
http://www.defendersource.com/forum/...ead-30938.html
heater, mod
D90 Heater modification Roadsiderob Defender Technical Discussions 8 March 30th, 2015 08:53 PM
What was your first modification / best modification? Carmel_CA_D90 Misc. Chit-Chat 8 May 24th, 2014 06:18 PM
ARB Modification for a 97 mjekogian Defender Technical Discussions 3 May 8th, 2010 09:34 AM
ECU modification w/3.9L to 4.6L Conversion severson Defender Technical Discussions 14 March 19th, 2010 03:56 PM
Parts drawings and custom modification thread - Let's share. Manimal Defender Technical Discussions 2 October 9th, 2009 11:34 AM
