built a pull-out bed out of workshop scrap - Defender Source
Old December 18th, 2013, 09:06 AM
trailer guy's Avatar
trailer guy
Ben Jones
Defender 200tdi 110 Hard Top
I decided to build a pull-out bed slide, as I'm far too short to be jumping in and out of the back of the 110 to grab my tools
I know these are pretty popular on your side of the pond, but they're not seen over here much. As well as being a tight bugger, I'm always up for a bit of a play and work-round, especially if it costs me as little £ / $ as possible. Just thought I'd share the results
The only thing I bought were the roller tracks (around £45 / $73 for the pair) I had some 3/4" ply knocking around, as well as some alumimium angle off cuts, so...
(apologies for the poor iPhone pics!)
ID:	86335   Click image for larger version
ID:	86337   Click image for larger version
ID:	86339   Click image for larger version
Old December 18th, 2013, 09:17 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ben, where did you source those roller rails? looks good also looks like your cross member needs some attention...lol!
Old December 18th, 2013, 09:19 AM
Very nice! I would recommend you add some retention for the bed platform and the cargo, so you are not killed by it in the event of a rollover.
Mark Kellgren
KM4BOR
Old December 18th, 2013, 09:20 AM
That is sweet.
Old December 18th, 2013, 09:24 AM
Looks like he has a headache screen there, Mark. A wussy one, but I guess it's better than nothing.
Great work.
Maybe we should have a section for stuff like this. Home brew solutions or something....There's one on the tractor forum.
Old December 18th, 2013, 09:39 AM
trailer guy
Ben Jones
I didn't think that would pass scrutiny! Did that the next day...
Plasma cut some 4mm sheet steel and welded it in
ID:	86342   Click image for larger version
Old December 18th, 2013, 09:42 AM
trailer guy
Ben Jones
Roller tracks are here:
http://uk.rs-online.com/web/p/convey...dules/4372832/
bit of discount made them about £45 for the pair.
------ Follow up post added December 18th, 2013 08:46 AM ------
Thanks Overlander, that's a good call.
The 40" toolchest is bolted down, through the ply, with coach bolts, inside.
Most of everything else is bolted down too.
There's a 3.5kva 8.0hp Honda generator in there, a 50ltr air compressor and a few other bits. All bolted down / to the side of the truck.
The pelicase and jack aren't, but they'd be worth doing, for sure, thanks for teh heads-up.
------ Follow up post added December 18th, 2013 08:47 AM ------
Cheers Rocky, that's very generous of you
Old December 18th, 2013, 10:21 AM
Bill Larson
Bill Larson
Good stuff! Thank you...
Old December 23rd, 2013, 09:11 PM
LaneRover
Brent
1965 109SW
Very nice set up!
I like the 'leg' to hold things up when it is fully extended.
Could you put a pipe fitting to also use that leg to help lock it in place when it is stored in the truck? Just a thought.
Old December 23rd, 2013, 09:40 PM
looks like a really heavy truck, all that weight inside and you tow with it regularly as well ?
Old December 29th, 2013, 08:33 AM
Doug it's the UK they'll put a horse box behind anything!
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 3rd, 2014, 06:29 AM
trailer guy
Ben Jones
Thanks LaneRover - and that's a good idea, I'll have a look at that, thank you
Yes Sir, Ren Ching is right - we'll tow anything over here!
To be fair, my Landy is a working vehicle, so that's what she's used for.
There's a lot over here that are just 'poser' vehicles, but mine's got to earn a crust.
She's pretty heavy, I must admit (3.5kva generator, 50ltr compressor, deep cycle Rolls battery, 240v inverter, all my air and electrical tools, 3.5ton jack, three pelicases with tools inside, the 40" tool box, axle stands, all the parts I keep on board for the servicing etc etc..), but it's all used all of the time!
I'm thinking of dropping a lot of it in to one of my trailers, so I can tow it when required. Not sure tbh... going to give it some more thought.
And yes, fully loaded, she tows trailers as deliveries for customers!
The epitome of a working girl...
ID:	87126   Click image for larger version
Old January 3rd, 2014, 11:12 AM
Dave you and I have been there and done that.
Old December 11th, 2014, 09:09 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Excellent ideas!!
Thanks for sharing
Old December 13th, 2014, 12:21 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
That's really sweet
left pull when braking paulb Defender Technical Discussions 19 November 7th, 2017 09:21 PM
1995 NAS Defender 90 Workshop Manual MDS Defender Technical Discussions 3 November 21st, 2006 05:58 PM
installing bed rail kit TDI Guy Defender Technical Discussions 2 November 3rd, 2004 07:28 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
Question Transporting a workshop manula in the field? Eric Siepmann Misc. Chit-Chat 3 December 8th, 2003 10:00 PM
