Building a roof rack - Defender Source
Old November 15th, 2010, 10:34 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Who knew learning how to weld and bend metal could be so much fun!!!! If you have 4 days and $300 bucks you can make your very own roof rack. That's right! $300. Granted, you need a few tools in your shop including a welder, drill press, table saw, grinder, and a few small things I don't even know the name of. Pics are below. Some of the welds are a bit chunky but give me a break, it was my first time. The outer tubes are 1.5 inch with 1 inch supports/steps. The flooring is a horse fence I stumbled on in OKC at a steel supply shop...not much fun making over 200 passes with the welder but it should hold around 1000 lbs according to my engineer helper. The basket is roughly 120 lbs and the ladders add another 40 lbs or so. Let me know what you think. Haven't painted it yet....that's black primer you see. More pics in post below....
ID:	33158   Click image for larger version
ID:	33160   Click image for larger version
ID:	33162   Click image for larger version
ID:	33164   Click image for larger version
ID:	33166   Click image for larger version
Old November 15th, 2010, 10:38 PM
good work, although it's hard to tell without a full pic of it mounted on the truck.
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
More pics. For those curious I'm running 255/85/16 with 2 inch OME HD front MD rear.
ID:	33168   Click image for larger version
Old November 15th, 2010, 10:46 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Sorry. Technical difficulties. Here's the finished product....
ID:	33176   Click image for larger version
ID:	33178   Click image for larger version
Old November 16th, 2010, 12:01 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Looks great Jeff!
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old November 16th, 2010, 02:10 AM
Chaucer
Will
93 110 | 97 90
I think the most important thing is that you did it yourself and you learned a lot doing it. You probably had fun doing too.
Old November 16th, 2010, 06:38 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Looks great! Nice crossbars
Semper Fi!
Old November 16th, 2010, 08:36 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
It was nice meeting you yesterday and as I said then the rack looks great! For someone who has never welded before that was a pretty big under taking and you did a good job.
Old November 16th, 2010, 06:21 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Thanks guys. The process was frustrating at times but overall a fun experience. Big thanks to Jonathan for the cross bars. Saved quite a bit of time. Guess I won't be buying a rack from you now but still think you have the 2nd best looking rack out there!!! Kidding. I like yours better than mine but couldn't pass up an opportunity to learn how to make one.
Old November 22nd, 2010, 07:22 PM
JBinAlabama
john
Series 2A ..more parts on the way
NICE JOB!
(I'm wondering how many welding helpers are engineers!)
That's a great project and looks better than most!
Old November 22nd, 2010, 07:32 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Thank you. The welding helper was an old timer that has been a jack of all trades. Rancher. Contractor. Horse whisperer. Civil engineer. Salesman. He's built skyscrapers, oil rigs, houses, highways, you name it he's done it. Couldn't have done it without him. You can clearly tell my welds vs. his......if you could even tell where his were. Welding is an art.
Old November 25th, 2010, 04:09 PM
jaygoss's Avatar
jaygoss
Jay Goss
I have some chicken coop flooring from Farmtek I'm not going to use- you're more than welcome to it.
Old November 25th, 2010, 04:12 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Thanks for the offer but I already built in the flooring..... Have a great Thanksgiving.
Old November 26th, 2010, 03:39 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Looks great. The corner bends on the 1.5" tube look a little scary, what sort of bender do you have?
Old November 26th, 2010, 10:38 AM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
A local muffler shop bent the basket tubes. Squeezed a bit at the corners. If there's a next time I'd use 90's like I did on the ladder.
Old November 30th, 2010, 11:39 AM
Looks great. One small eensy weensy thing...the round tube on your ladder rungs will be really slippery with muddy or wet boots. If it were me I would make them from either angle stock or use some expanded mesh on the tops.
Old November 30th, 2010, 05:21 PM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
I initially tacked on square tubing for that reason and liked the look of the round better. But you're right, it is slippery when wet.
Old November 30th, 2010, 09:10 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Nice job, Jeff. As for the ladder, just get some no-slip tape and apply to the rungs. Done. Hope to meet you at one of our Happy Hours. Mark
Old November 30th, 2010, 09:39 PM
jaygoss's Avatar
jaygoss
Jay Goss
Ditto- count me in for a happy hour as well
Old November 30th, 2010, 09:47 PM
James Pierce
James Pierce Jr.
Next time you drive all the way to Oklahoma to build a rack you can use my Baileigh tube bender and notcher
ac, rack, roof, roof rack
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
roof rack swap RiMiD814 For Sale - Parts 2 March 5th, 2006 12:04 AM
Roof rack question... oldscratchggf Defender Technical Discussions 7 February 10th, 2006 02:44 PM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
FS/FT RoversNorth roof rack Hans For Sale - Parts 6 May 8th, 2004 07:22 AM
