Brake pedal - Defender Source
Old March 16th, 2016, 04:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Brake pedal
What is the easiest way to transfer the auto size pedal on the right to the manual pedal box on the left?
I thought initially of dismantalling the whole thing but when I looked at the crappy welds... I think I might just cut off the foot pedal and reweld on to the good box.
Also, is there a law or a rule that says you need a big pedal for an auto truck?
Rent my
Old March 16th, 2016, 04:36 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I just weld them on... No law that I am aware of stipulating that the pedal has to be bigger
Old March 16th, 2016, 04:49 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thanks- I thought that would just be too...easy?
Rent my
I have small pedal with no rubber on it because I am a bad ass motherfucker with complete disregard for the law.
I would just cut and weld it if it were a customer's vehicle.
Old March 16th, 2016, 04:55 PM
Unless you drive with both feet, leave it be.
Old March 16th, 2016, 08:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
ha ha
We followed Boggs down a trail last weekend that was so steep I needed both feet on the brake pedal.
I'm gonna cut and weld.
Might even go oversize and "HD".
Rent my
Old May 6th, 2016, 04:04 PM
pshaw's Avatar
pshaw
Peter Shaw
1965 SIIA 88"
Nomar, are you selling the pedal box after you cut & transfer the pedal? I'm looking for a brake assembly to mock up power brakes on my SIIa restoration. Don't need the servo, I will likely source an 8" from somewhere.
Peter
Old May 6th, 2016, 04:59 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I'm going to take a look, but I think I have a metal plate that is the same size as the automatic pedal that bolts onto the manual brake pedal. IIRC, it was part of the kit from Ashcroft many, many moons ago.
Email is
Same place, new dogs.
Old May 6th, 2016, 05:16 PM
Roverlab
Trevor Griffiths
Uggh, can't find it. sorry.
Email is
Old May 8th, 2016, 12:53 AM
The arm comes off pretty easily. IIRC you drift out the bearing shaft thing. Assuming they are the newer style mid-94 and up it should transfer over fine.
Old May 8th, 2016, 09:33 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I never updated this...
In the end, I just cut off the larger foot pedal(from the smashed pedal assbly) and welded it onto the good pedal- after I cut off the small pedal.
Literally 5 minutes of grinder cutting and 3 minutes of shit-welding that nobody will ever see...
One was a '94ish, the smashed auto one was a '97, so like Ron said it looks like I could've swapped the whole arm out.
Rent my
brake
Pressing brake pedal turns on parking and brake lights burlsube Defender Technical Discussions 9 August 28th, 2015 11:21 AM
Soft Brake Pedal Issue.... greend90SW Defender Technical Discussions 3 December 29th, 2007 02:25 AM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
