Brake lights not working - Defender Source
Old August 7th, 2008, 10:39 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Does anyone know if the D90 brake light switch can be exchanged with a different model or parts inter-change?
Mine is out due to water damage of some sort and I just wanted to know what others have done to remedy this problem,...maybe a water proof model of some sort.
Old August 7th, 2008, 12:07 PM
Just get a new switch they are readily available and damn simple to replace. Think they are around $30. I think it took less than 10 mins to remove and replace mine last spring. White plastic thing on top of the brake booster bracket. Two wire plug and set the depth nut the same as your old one screw it in and done.
Its fairly common for these to wear out.
Old August 7th, 2008, 01:08 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
great!!, many thanks
Old August 18th, 2008, 04:29 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
It turned out one of the wires was loose on the switch...
Why is it we never check the easy stuff first?
Regards
Tom
brake, ht, lights
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Help!!! State Inspection No brake lights !! Hammertime Defender Technical Discussions 11 February 10th, 2008 08:09 PM
weird brake lights sflash868 Defender Technical Discussions 4 April 17th, 2006 11:37 PM
Brake Lights Stuck ON RoverWrecks Defender Technical Discussions 4 August 21st, 2004 11:26 AM
