Best Shocks/Springs Upgrade for a D90 - Defender Source
Old November 16th, 2012, 08:29 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
I have stock shocks/springs on my '95 NAS D90 ST that I would like to upgrade. I don't plan on doing much wheeling at all, maybe some light trails down the road. And I don't plan on towing anything or carrying extra heavy loads except my skinny wife, 2 small kids, couple of bikes attached to the tow hitch or my Rola Adventure system packed with vacation shit. I would like to get 2 inches of lift. I don't want to cheapest ones out there but also don't need the most expensive.
What do you guys think are good for my needs? (Josh - I did a quick search but didn't see anything
Thanks!
Update: I also plan on adding an Arb bullbar front bumper with winch in the future.
Old November 16th, 2012, 08:33 AM
rovertrader's Avatar
rovertrader
Dale
I may have a little tunnel vision as I have used the OME for the past 20 years on all my Defenders. I have used the RTE on Discos and been well pleased there as well.
Old November 16th, 2012, 08:44 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
the Olde Man Emu shocks of course!
Old November 16th, 2012, 08:47 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Ome
I figured I'd get a bunch of OME calls from you guys but they seem to be on the high end, no? What about Terrafirma medium duty? They seem to be in the medium range price-wise? Anyone have them? Or OME all the way...?
Old November 16th, 2012, 09:21 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
If you are keeping stock sized rubber, I'd say keep the stock springs. I think added protection like sliders or diff guards and some recovery would go further/better for you for running light trails.
For the front bumper, maybe just a Mantec if you aren't planning on anything too crazy off road wise.
Old November 16th, 2012, 09:57 AM
I can't imagine, why you would lift it....
Koni 8240SPX are fabulous for ride control and comfort. OMEs are a bit stiffer than stock, and have the same mediocre ride. If you want stiffer, there are Bilstiens.
Old November 16th, 2012, 10:16 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Thanks for the info. I'm not doing this just to lift it. I'm upgrading 17 year old shocks & springs. All the replacements/upgrades seem to offer this.
Old November 16th, 2012, 10:36 AM
You state you do not plan on any real off road use. Why lift it? Mileage, handling and ride all get worse with a lift.
Old November 16th, 2012, 10:40 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I'd replace all your bushings while your at it. If they are original like everything else, they are probably a little worn.
You can do Bilsteins and some Land Rover Heavy Duty Springs. I like the Bilsteins with stock springs.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 16th, 2012, 10:45 AM
Originally Posted by waveridin1959 View Post
I'd replace all your bushings while your at it. If they are original like everything else, they are probably a little worn..
My opinion... Only replace them if they are dead. The quality of new bushings is horrible compared to the originals.
Old November 16th, 2012, 11:24 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
For Bigger tires down the road. Don't care about gas mileage.
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old November 16th, 2012, 11:39 AM
Spring lifts do not affect tire clearance.
Old November 16th, 2012, 11:51 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Uhh what?
Old November 16th, 2012, 11:57 AM
Originally Posted by Jake1996d1 View Post
Uhh what?
Springs are not what are setting the travel limits of the axle. Bump stops control the compression travel limit. Shocks control the extension travel limit.
A spring lift makes is "seem" there is more clearance as it is harder to reach the bumpstops. But, you can still reach them and the clearance is exactly like stock. In order to change clearance, the bumpstops need to be longer. You would obviously then want longer or relocated shocks and brake lines to get back the lost travel. Trimming is a heck of a lot easier...
What size tires is the OP planing?
Old November 16th, 2012, 12:25 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Thanks all. I think I have what I need (and then some...)
90, d90
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
D90 TD5 ECU Chip upgrade? Should I or not? adibitar Defender Technical Discussions 11 September 1st, 2005 01:22 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
