Best place for a subwoofer in nas d90 soft top? - Defender Source
Old April 12th, 2017, 07:23 AM
jkins
john
95 Defender 90 - Beluga
I have read a few of the older threads on subwoofer placement in a nas d90 soft top w inward facing jump seats but I wanted to see if anyone has more info... what have people done lately?
I would prefer to buy something as building anything is a 6 month job for me!
Does this one sound good? Great? Seems inexpensive but am I getting what I pay for?
https://www.lrisolutions.co.uk/cubby...er-90-110.html
Also looked at the mud one that fits under the cubby box. Thoughts on that solution?
Other ideas?
Thanks!
Old April 12th, 2017, 09:48 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I think I would go this route here. It has a small footprint and raises the cubby box so it can be used as an armrest. It's a win-win.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old April 13th, 2017, 12:28 AM
sad_story's Avatar
sad_story
andre
95' D90
I put them under seats .. 8" woofer driver an passenger side ... the amps under front passenger ... those under seat "boxes" make perfect enclosures when lines with dynmo mat
Sent from my iPhone using Tapatalk Pro
Old April 13th, 2017, 12:38 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Thanks!
It sounds good. That is the same unit LR put in the Puma with upgraded sound system. I bought one and mounted on the back of my cubby in the 110 Puma. It is not a booming system, but fills in flat spots from the stock Alpine system. The logo is upside down (LR had custom Alpine units with logo placed 180 out).
Any powered sub that fits back of cubby will be similar.
Hopefully you garage this truck, and park safe in daylight. Soft tops cost more than audio equipment, and would hate to get a top slashed for a $150 sub.
KGH - “Stinky LR diesel” Defender Snob
Old April 13th, 2017, 12:44 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I'll be experimenting with a couple of ideas. I bought an entire sub system from the boss that fits flush with the top of the center seatbox. It's a custom fabbed steel enclosure that fills the space above the tc. Should be the most stealthy. My other concept is an abs active waterproof 6.5" sub tube (single or double ended) that fits in the gap between the jump seat's vertical braces and the tub wall's radius. Not quite as stealthy, but could be nearly invisible, better sounding/feeling, and indestructible.
"Barry is correct!"
Old April 21st, 2017, 05:50 PM
sad_story's Avatar
sad_story
andre
95' D90
So I get Tre Doud praise for the sound quality in my truck .. I have 8" woofers under the front seats
Old April 21st, 2017, 06:15 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Originally Posted by KGH View Post
It sounds good. That is the same unit LR put in the Puma with upgraded sound system. I bought one and mounted on the back of my cubby in the 110 Puma. It is not a booming system, but fills in flat spots from the stock Alpine system. The logo is upside down (LR had custom Alpine units with logo placed 180 out). Any powered sub that fits back of cubby will be similar. Hopefully you garage this truck, and park safe in daylight. Soft tops cost more than audio
I have the same one. Sounds pretty good. Got it off eBay Japan. I would swap it out for something else if I could find something that fits as nicely. There is a more powerful Kicker one I suspect will work but haven't gotten to try yet.
90, ac, d90, nas, soft top, top
D90 Soft Top Stero system... DiscoDino Defender Technical Discussions 2 July 3rd, 2005 12:37 AM
Looking For A D90 Defender White Soft Top FREEDOM Wanted 0 May 10th, 2005 02:26 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
wrecked 1994 d90 soft top BudThomas For Sale - Parts 7 January 13th, 2004 10:32 PM
