Belt for A/C unit - Defender Source
Old January 6th, 2013, 07:59 PM
Gordonhurst
Mark
Belt for A/C unit
How hard/expensive is it to install a new belt in the A/C unit in a 94 NAS D90?
Old January 6th, 2013, 08:41 PM
Is the belt off and you just got the truck!
Old January 6th, 2013, 09:06 PM
Gordonhurst
Mark
Not yet. Looking at one that needs this repaired.
Old January 6th, 2013, 09:12 PM
if the belt is missing ... it's possible the compressor is faulty ... and that's a lot more serious. Someone may have cut the belt to prevent it turning the compressor ... they could have just unplugged the electrical connection but then they'd have to explain why the AC wasn't working.
A new felt is a bit fiddly but still a DIY job - it's a standard size available fro auto zone or napa.
Old January 7th, 2013, 03:34 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Hey Mark -- Welcome to the board... I actually just moved from Upper Montclair to West Caldwell... if you end up getting the truck and needing any help, let me know.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
Help.... acess to flasher unit Defender50th Defender Technical Discussions 2 July 18th, 2005 04:57 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
